1 hour ago, demiosdd said:
I think the rims atm from a quick measure with them still on car so might a bit off are 235/45/17 with a 17x9 +38
Well if that’s the case then it’s only a 2mm difference... to be sure you should have a look at the inside of the wheel spokes.. it will be engraved somewhere.
if you have the measurement correct then 2mm should be fine (as long as you’re not 1-2mm off the suspension lol) just make sure you also check the fronts at full lock both directions.
I just won some Work Meisters,  3 piece SP1.   Plan on seeing if they work with my GTT.   Should be interesting, lol.   Any idea what tires a guy should run?
Work Meisters S1
5x114.3
18x10+22
18x11+22
Edited by walperstyle
Work Meisters S1
5x114.3
18x10+22
18x11+22
Minimum 3 degree camber and ultra stretched tyres ? 235s and 245s
  • 2 months later...
Thanks to everyone's input here.  Been a lot of help reading through this.  I have a bit of a different situation.  I have a GTT with GTR fenders added on.  I ordered 18-9.5 +12 LM GT4s but they don't fit as I think some of the original GTT fender is in the way.  The shop is now telling me to order 18-9.5 +22 up front and 18-10 +22 for the back.  Any thoughts on this?  I don't want to end up with a second set of wheels that don't fit.  Car came with 18-10.5 +22 TE's but they were rubbing a bit so I was looking to change them out.
Thanks
Edited by stukinthe90s
misquote
(Just for future reference for other people wanting fitment suggestions)
I've got Work Meister S1 3P's on my 34 GTT.
18x9 +18p front on a 225/40R18
18x10 + 18p rear on a 255/35R18
Fitment is near perfect. Minimal camber in the rear too. Fronts I could probably have gone another half inch wider and cleared perfectly fine. Car is not sacked on its ass though as I hate guard rub. Only get a tiny bit as is if I go over a solid bump with a few people in the car. I have slightly pulled my fenders however.
  • Thanks 1
Thanks
Strange that they don’t fit. What tyres you running? I have 18x9.5 +20 on my fronts with 235 rubber and they clear easily
maybe you are running too much tyre on the front?
Otherwise you could get a wheel alignment and possibly adjust camber half a degree
The TE's have 265-40 on them.  I'm not sure what tire was put on the LMGT's when it was test fitted.  I'm having a shop handle all this for me as the car is down for a full rebuild.
A 265 wide tyre should only be running 35 sidewall not 40. This should solve the issue
  • 1 month later...
I’ve decided I rather run more tire and less offset. I’d like ro run 235/40 up front and 255-265/35 rear. Trying to decide if I wanna try to make 18x9.5 +22 square fit or go the safe route and do 18x8.5 +30 front and 18x9.5 +35 rear.
Edit: unfortunately the wheels I have picked out dont have a 18x9 option or I would opt for that for the front
Any advice? I’d like to avoid poke if I could. I know 235/40 on 9.5 will stretcn a bit but it’s not too over the top. My car also has GTR brembo’s so I gotta make sure everything clears lol
Edited by Ryno34
  • 4 weeks later...
both options will fit, the square set will look better and more chance of clearing the front brakes depending on the disk type.
  • 6 months later...
Hi Im looking at getting some work GT5 wheels in 18 x 9 +30 front and 18 x 10 +38 rear.  Car is fairly low on BC coilovers and all guards are rolled. Will the 18 x 10 + 38 clear the coilover fine??  Will it sit fairly flush or better off going a bit more aggressive offset. Don't really want to be cambering the wheels or having crazy poke. Just after a nice clean look.
Should be more than fine.
There's a lot of space in the rear of a 34 on the inside, I don't know too much about the BC's vs other coilovers back there, I have 18x9 +30 all round and have something like 40mm clearance on the inside. It'll poke a litttle on the rear, but 10+38 is a very common size for the rear of skylines in general in regards to that.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
