Do you run coilovers? Have your rears scrubbed out when crabwalking really steep driveways? I want 265's on the rear now...
no coilovers just really really low springs and they havent scrubbed on steep driveways, only scrubs on big bumps if im going fast enough
dont get +40 pinch.gif atleast get +35 or somewhere around that
even with my 9.5 +34 i could go atleast +30 without rubbing and still they wouldnt stick out.
Hmm.. so what would you recommend out of these two:
18x8.5 +35 Front and 18x9 +32 Rear
OR
18x8.5 +35 Front and 18x9.5 +40 Rear
No guard rolling, don't want it to scrub of course either.
With your idea, would going for a +32 (even if it's 9") be a better fitment to the outer guard? Not really after "big width" rather just a nice look.
  • 1 month later...
I am having the same problem with getting my head around all the offsets etc..
Im looking at getting 19" x 9.5 +22 but im not sure if they will fit.. Everyone else seems to run 18"s only.. I just want something different..
My car has coilovers but is at about standard height.. The body kit should make it look like its a bit lower to the ground as I dont want to lower it because they wheels may not fit with out rolling the guards..
Pics would be sweet when you get it done :yes:
Running cr kai's - F: 18x8.5 + 30 (from memory) with 225 rubber R: 18x9.5 + 38 with 265 rubber.
Conservative (no rubbing issues), fill the guards with no work done, look nice. Excuse quick photo (bad quality)
Edited by TM7GTR
I could do with a bit of advise.
About to buy TE37's:
Front: 18" 8.5 +30
Rear: 18" 9.5 +40
Am I going to have any issues?
Will be fine, exactly what I am running except my rears are +38 offset. +40 is the offset of the stockies I believe
The only issue you're going to have is that the wheels have flat spokes :down:
The fronts will be fairly flat but my rears have a bit of concavity, and only 2 offset lower.
TE37's are pretty exxy though, have you looked at Varrstoens's or Rota Grids?
I have never seen 9.5s in that offset with concavity :huh:
18x9.5 +22 at the back will sort that out though :thumbsup:
:sick:
The TE37 is a proven strong, light wheel that is FAR superior to the above mentioned.
:sick:
They aren't crazy concave of course, but they are far from flat. TE37's easily one of the best ever, and the cost reflects so.
The only reason I mention it, is I've found a set for $2500 delivered, seem alright condition, in the above offset I mentioned.
So as long as +40 will fit, I'll deal with the cosmetic aftershock. At least they will fit nicely, regardless of the outter face concavity.
I hope. ;)
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
