Hi, new to the forum. Just got a '98 R34 GTT Sedan. Looking to swap out wheels. Is anyone running hub adapters? Looking to fit a set of work meister s1 3p, 18x8.5x10.5 +49. Tires are slightly stretched. Bolt pattern is 5x130 ( they were on my Porsche 944 turbo ). If I get 19mm adapters that go from 5x114 to 5x130 that should give me 20mm offset, correct? My only worry here is if the stock hub studs would be too long, hitting the back of the rim, popping out of the hub adapters. Does anyone know the length the stock hub studs stick out from rotors? Just trying to see if I can make this work. Thanks in advance.
I don't think that that's your only worry.
First up, it's not a problem in itself. If it happens, you just put shorter studs into the original hubs.
Secondly....to try to fit a 10.5" wheel on the back of an R34 is an exercise in getting the offset absolutely perfect. You'd want to be damn sure (measure it yourself 20 times) before committing. Because you don't have the option to do anything except just throw that wheel onto the (probably only choice of) hub adapter, you only have one outcome. Either it fits or it fouls and you probably can't do anything about it if it fouls (beyond guard mods, perhaps coilovers, whatever it takes to find the required space).
  • Like 1
I'm running 18x10 +20mm rear on an R34 2 door GTT and it's too wide. It works, just, with 265/23 tyres and rolled fenders. But it would be about perfect at +25mm offset. If I were buying the wheels again - bought originally for my 350z - I would opt for 9.5 rear then f*ck around with a 5mm spacer if necessary.
Edit: I should add that the coupe has about +10mm body width at the rear fenders.
Edited by GoHashiriya
  • Like 2
Need some advice myself.
These are my wheel options
19x8.5 +35
19x8.5 +43
19x9.5A +25
19x9.5A +35
19x10B +25
19x11B +18
I'm thinking 19x8.5 35 front and 19x9.5 35 rear
Not many people running 19's, I've mostly seen 18's.  But staying between 30 - 35 offset seems to be the consensus
I'm wondering if I could do 9.5 +25 or 10 +25 in the rear.
I'm looking for flush, not slamming the car or any camber.
I guess its hard for me to visualize not knowing where the fender is.
What car? Do you not have it in possession?
The reasons I ask are:
  • Obviously it differs between the different models as to what will fit, including choices like strut/coilover choice,
  • It makes no sense to be buying wheels for a car that is not in possession. When you have it in possession, you can actually measure what is on there and how much clearance you have. Then the answers just fall from the sky.
  • Like 1
Yes, so then my advice is as I have given in the past. Don't rush it. You don't have to let the excitement make you make bad decisions. You don't have to have the nicest wheels immediately. You can wait a few extra weeks. Get hold of it and measure it yourself.
It is important to realise that the subframe might not be evenly set left-right across the car and you could easily have a 10mm difference left to right. And if you're trying to do this from internet measurements and pushing it to the last mm, you will possibly find yourself with it rubbing on the inside on one side of the car, and on the outside on the other. The only way to win in those circumstances is to go with a more conservative wheel choice, because, while you can put a 5mm spacer on one side, there is no such thing as an "unspacer"** for the other side.
**even if I did manage to convince some numpty that they existed abut 20 years ago.
5 hours ago, myktek said:
forgot to mention, R34 GTT Sedan
The car is not with me at the moment, in the shop getting some maintenance work.  I just got it a few weeks ago
I agree with GTSBoy on this, but I will say that 19x10 +25mm will be a stretch on an R34 sedan body. Out of your options, I'd wager the 19x9.5 +25mm as being the closest to perfect (flush), but I'm not considering the implications a 19" wheel will bring over an 18". When you get real close to making it perfect, your alignment settings will have an impact too; I rubbed very slightly on hard corners/rumble strips at -2.5 rear and not at all when set at -3.0.
Just trying to make wheels I already have work. If I cant get the rears to fit properly, Im looking to get Okubo Factory rear fender flares. The adapters have been ordered from Caold in Australia. So itll take a bit to get to me in Hawaii.
Thanks for the specs and pic. So my 10.5x18 at +20mm definitely wont fit. Lol. Lucky I ordered a pair of 15mm and 20mm adapters. Ill keep this post updated Once I get them.
  • 4 weeks later...
Adapters came in. Got them from Caold Technology in Australia. 20mm in the front and 15mm in the rear. Front looks like it could take another 5mm. Work Mesiter S1 3P 18x9.5 and 18x10.5 +49. Coilovers are Blitz, may go lower a bit but the exhaust is already scraping alot of driveways. 😂
  • Like 1
  • 2 months later...
You're right, the front needs about another 5mm and a size wider on the tires. Rear needs to lose about 10mm in offset.
The wheels work well with the car though, I would just see if there's any machining that can be done with the adaptor and original studs. Studs are easy to replace so you shouldn't be too frightened about shortening them. Just buy some spares first. Of course it's your car, not mine, so do what you want.
On 1/9/2024 at 2:26 PM, myktek said:
Konig Heliograms
19x8.5 ET32 225/40/19
19x9.5 ET35 265/35/19
On Tein coilovers, no rubbing
Fitment is nice and overall it looks good, albeit 19s are too big for me - I've been tempted to go with 17s. Did you roll the fenders and is there any rubbing up front at lock?
I initially rubbed only on the driver front because of my fat ass, lol, so just adjusted the coilovers to support my 220 lbs of weight lol.
Didn't need to roll fenders or camber.
  • 5 months later...
ER34 GTT Altia
I want to have such setup:
18x8.5 ET35 - 235/40R18
18x9.5 ET22 - 265/35R18
I have no worry for front.
I'm confused about ET22 rear.
Is anyone ride on 265 at rear with ET22 or less, I don't want to roll the guards.
  • 1 month later...
Wheels: Work VS-XX
F: 18x8.5 +28 r-disc  235/40/18
R: 18x9.5 +32 a-disc 255/40/18
Regarding the fronts:
  • I'm not sure if I needed to get r-disc since there's about 1/2inch 2/3inch gap between the R34 GTT brakes and the wheel.
Fitment:
  • I would say it is almost perfect. The fronts could be a bit more aggressive though.
  • No camber adjustment, just lowered.
Edited by ledvd
  • Like 3
  • 2 months later...
Since this is the page where i found myself while searching for wheel fitment, i will add the ones im looking to replace too.
Fenders arent rolled, so in big bumps they touch the tire (tires could be narrower). no any adjustable arms, so the camper is what it is (dont know).
Wheels: 5ZIGEN Fireball
Front: 18x9.5 ET12 - 245/40
Rear: 18x10.5 ET25 - 285/35
So, they simply stick out too far because very wide + very low offset (at the front).
At least it's up nice and high so they shouldn't bang into the car too much.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
