Need Some Vic Road Knowledge
BRUNSKIGTST
 Share
My story is was on freeway, and there was debris on the road, a sheet metal, first big truck in-front of me ran over it and couldn't see it in time to avoid it so i ran over it and my tyre pop , puncture right on the side wall or near it and can not be repaired.
question is can i call vic roads and explain the situation and send them the bill for new tyres because they the one supposed to monitor and keep freeways cleans to prevent this stuff from happening (or who is responsible local council), will it work or they cannot do anything about it?
or i have to get it fixed and no one is to blame :(. so sad because i saved lots of money to get truck licence and this happens :(
goodluck with that, sadly more then likely it came off a truck also,
even if you had a case it would take months and big money to even get to court,
sadly its just one of those things, as it was debris; most likely from a truck, it wasnt a power pole or street light that was on the road.
If every person who ran over material or hit an oil patch was to sue the local council it would cost alot of time and money. ALSO if you got to court they would argue that it was your error of judgement to not avoid the obtrusion.
You will be better off just paying for new tyres and going about your business, I had a bad luck with buying my car, got it cheap but still didnt expect the engine to be sick, so I have had to do a rebuild already after just buying it.
Sadly its just life.
IF you went INTO vic roads and the manager laid into your car with a baseball bat AND you got it on camera AND sent it to ACA/TT.............
they would do a story on "hoon car breaks gov't employee's baseball bat" and you'd probably be hit with a bill for a new bat.
welcome to Victoria
Vicroads can't be held responsible as it more than likely (most definitely) came off the back of a truck, which can happen at any time and they can't monitor this any more than you can. In the event of this, if you see the truck it comes off and take note of their details then you can hold them responsible for the damage, but if it was already there on the road and you simple hit it...yes, bad luck for you :(
Where councils are concerned, is with regard to things they are in control of and responsible for maintaining over the long term, e.g. bad potholes, falling branches from overhanging trees that should have been cut back. Even then, as Hamish said you're likely to cop a bill in the mail for the tar to fix the pothole or a notice from the EPA for taking out a tree branch.
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
