hey all just wanting to know what you all think of my bodykit idea? it for my 1993 r32 gts-t...oh and its white.
pic 1 & 2- M-sports sideskirts and rearbar
pic 3- TRUST front bar (my bar is currantly getting sprayed at crash repair shop)
if you can think of any other skirt/rearbar combos that will go with my trust frontbar please let me know, and pref give me a link to some pics! cheers
hopfully the skirts and the front bar should come down to the same level unlike the stock ones where the bar comes down a bit lower?
ps: the car in the second pic belongs to "cheeky32". v-nice car btw. please let me know if you donot wish for me to use ur pic and i will replace. :cheers:
thanx guys
should i get a gtr wing also? or will it be too mutch?
https://www.sau.com.au/forums/topic/39068-what-do-you-think-of-this-kit/
Possibly the do-luck side skirts and rear bar? Whats the m-sports web page? I havnt seen their kits before, i was considering getting the do-luck type 2 kit, but quite possibly might be excessively low. As in 2-3cm clearance, with current suspension. :D
the do luck and vertex kits are my fav's for the 32
sorry to hijack but does anyone know if vertex ever made a drift kit for the 33 like the 32's??  ive never seen it.  if it does exist can someone post pics??
i dont think they do, i put a post up a while ago and came back with nothing -- maybe we could adapt the kit used on the r34 but not sure!
yeah they did, but it wasn't run for long. A few mobs in japan however cloned it and modified it slightly n sell it as their own... i'll grab some pics for you.
Here's one that a bunch called Garage Axia clone... moulds should be done n ready in VIC n QLD soon.
Anyways, hyaaa back on topic yer sea lubbin barnacle! :D
ps: the car in the second pic belongs to "cheeky32". v-nice car btw. please let me know if you donot wish for me to use ur pic and i will replace. :mad:
thanx guys
the prices i qouted you on include the original jap rear bar, and my side skirts. there is the one set only and the rest will be my moulds.
Trent
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
