Hi all, finished replacing the xanavi unit in our S2 C34 stagea on the weekend, as when we got the car it didn't work. All is working now, except I can't seem to be able to play a cd. I insert it and it says something in jap, but nothing happens. The a/c bit works, as does the tv ( no picture though) . Do I need to select cd somewhere or should it start playing once I've put a disc in. Any help appreciated.
https://www.sau.com.au/forums/topic/390699-xanavi-cd-operation/
I bought another unit from Nisswreck, which is the one i fitted to the car. Everything else works, except if i put a cd in it wont play it, but if that cd slots only for the sat/nav disc then that explains why :thumbsup: Im guessing that other stageas on here must be fitted with cd stackers. If so, where abouts do they install them, and if one hasnt been fitted before is there factory wiring already run in place. Might have to buy one.
Mine has the same unit(for the prime edition stagea) i bought one of ebay and lent it to Kamikazi motors but they ripped me off and i lost it , the reason i asked is that a mate of mine works at RMIT and an engineer workmate of his , said that he may be able to convert it to english like i have wanted to do for three years now, could be an option.do you know of another in melbourne , by the way i have the CD
I dont know of another one, but if he wants to borrow the "broken" one and see if he can get it back up and running, then see if he can convert it its just sitting here doing nothing :thumbsup: . Also what does the "cd" you have do?
I've got a Xanavi head unit and i am able to play audio cd's in the slot behind the head unit. When it is inserted the controls appear on the touch screen and if the climate control is on, it pushes the display to the right of the screen. If someone can come up with software that'd convert the Japanese to English, I'd definitley be interested.
  • 1 month later...
I have the same unit, but the screen doesnt work. It occasionally flickers on when we start the car then dies. I have disassembled the unit hoping there would be a loose cable/bad joint, but no success. Anyone have some experience with this problem before?
if i were to remive the unit completely, how would i control the AC?
when i changed the stereo i had all the dash out as normal and because the wiring loom was disconnected the screen was dead , being a sparky and an inquisitive person i remembered that there was a wire that disapeared into the dash that i disconnected on the install, maybe somewhere in the loom a fault exists that isolates the screen.
I haven`t tried a CD in the sat nav drive but i will try and let you know , on the english conversion , nobody seems to know or it is too hard but I still have a contact at the RMIT and he will have a go at the conversion, my son Adam apparently spoke to someone in Worri Yallock who change the Xanavi head unit and now has a spare but i have yet to see it.
Hope this helps
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
