wouldnt a simple yes or no be easier than writing all that ?
and also do you live in or around eliz ?
Almost certainly would be easier; but imagine the sense of achievement you'll feel once you've mastered the forum search function.
Ten thousand threads about the same topic doesn't make the forum very productive, so search first.
Edited by Daleo
id use more time searching for it than making a quick thread and someone posting a simple "yes" "no" :)
Search "m35 ball joint"; 8 results.
This one is the second one; http://www.skylinesaustralia.com/forums/topic/382006-m35-front-ball-joints/page__p__6130708__hl__m35+ball+joint__fromsearch__1#entry6130708
Do you want me to paraphrase it, so we don't waste any of your precious time? You're obviously muuuuuuuuuuuuuuuuuuuuuuuuch too important to make any kind of actual effort to benefit yourself. rolleyes.gif
being a lazy f**k runs in my blood :)
Then you're in BIG TROUBLE with this car!
And yes, I am down Elizabeth way these days - I did send you a PM letting you know this in case you needed to see a complete car as a guide?
would have been you then driving past my work the other day on peachy road, i work at exide technologies :)
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
