So, about to buy a couple of new tires (finally) and I've been looking around for what I want to grab, but unfortunately most of the advice that I've found (particularly on here) is pretty much for the turbo model Skylines and generally high performance cars.
Now, my R34 25GT isn't a Hyundai Getz, but I don't think it's really a "performance car" either, so the more I think about it the more I think I perhaps shouldn't be spending perhaps $250 a tire on RE002s or something of the ilk.
I mean, I definitely want something decent, don't get me wrong, I want something that will keep me on the road and will most definitely grip in the wet, I'm not looking to skimp.
I just want people to tell me realistically what I should be looking at, and if I really am looking at the right mark.
Tanks,
Teir.
https://www.sau.com.au/forums/topic/390742-tires-for-a-na-skyline/
Dude would you really put RE002s on a smart car? (if they even come in a size that'll fit them)
I mean, that car barely hits 100km/h with its little 2 stroke engine...
I'm just asking if I'm going beyond common sense...
BUT... if the consensus it to spend the money, I'll spend it.
hay i had an r34 gt once, i personally wouldnt go all out on a set of tyres , like i mean look at those wheel and tyre packages you can buy they still stick in the wet, and clearly not being a turbo, you arnt circuit racing so something decent but you can definently get a set of good dunlops for $200 each, personally wouldnt spend anything over $200 on a no name brand tyre.
No name brand? Your mean the RE002? It's one of bridgestone's premium tires.
I would put somthing very decent on a smart car, think when your on the freeway at 130km/h (NT FTW) you wont somthing that will grip and wont deterate at the speed. I have tryed both cheep and exspencive and there is a distenct diffrence.
Well the money it is by the sounds of it...
Any last comments by anyone?
Specific recommendations?
My tire guy (family friend) is saying there's a pair of Michilins I should buy that are $15 more than the RE002 if I'm going to spend that much on tires, he reckons they're much better for the price.
I got Kumho KU31s on my NA 34. Cost me $700 for 235/40/R18 and 245/40/R18. I think the R34 25GTs came out with 205/55/R16's on them so my speedometer would be out by about 3kph.. Plus, it's not like the car will be having any traction issues being an NA and all so I don't think really expensive tires are really required UNLESS it's something that made you feel better (in the way that you will have more grip on the road).
Cheers.
I've always been happy with Falkens. Always get good life from them, and they seem to hold the road pretty well, wet or dry.
Currently running ZE912s. Good value @ under $200 each.
Another I have had some success with is the Bridgestone Potenza GIII.
Good too see a few more considered answers now, thanks guys.
And yea, I can loose traction, done it before, with shit tires in the wet, but I've posted plenty about that already.
Looks like I'll be going for $200 Toyos.
The tires that came with the car are 225/45/17, but I'm gonna be chucking on 235s as they're ~$50 cheaper and well.. more rubber...
Thanks for the input!
Teir
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
