FOR SALE MY R34 GTR V-SPEC
Ok a very very regretful sale, but un-fortunately it must go.
Listed below are the specs on the car;
Make: Nissan
Model: Skyline
Series: GTR V-Spec
Year: 10/2000
Colour: Bayside Blue
Kilometers: 58,069 Genuine
Extras: Nismo cat back exhaust system this came with the car
Viper alarm 855XV system
Alpine head deck with in-built hands free phone system and I-phone connector
15% Tinting done on it too
Price: $45,000 which is more than fare
About the car:
Working at Top Secret Imports it didnt take me long to see that my Toyota Supra had to go to make room for the all mighty R34 GTR. Being a picking and fussy prick it took me almost 2 years to find this car, Many came through the shop but wernt for me i didnt even want a bayside blue one, But then as soon as this came up OMG i just had to have it then when the car was in front of me i found i made the right decision.
The car was a 4.5 grade and was lucky to get the factory central locking remote with the car, its pretty much stock standard no mods done on the vehicle apart from the nismo cat back exhaust. First came in with
44,000 km
and now has 58,069 km and all four tyres have just been replaced with RE001
GDZLAR number plates will be $500 more if wanted with the car!!
The car will have a full service done on it which will include:
Royal purple oil
Genuine oil filter
Genuine air filter
Genuine fuel filter
Genuine getrag oil
Redline oil for the diff
Spit fire triple platnuim spark plugs
and much more
A full inspection on the vehicle
If you have any other questions about the car or enquiries please call me on: 0420-293-675 or pm on the forum.
https://www.sau.com.au/forums/topic/390753-r34-gtr-v-spec/
Man thats a nice car dude! Do you a deal keep it for 3 years and I'll buy it?
Haha sadly a house has gotta come first sigh.
Really nice car at a GREAT price!
Goodluck with the sale!
https://www.sau.com.au/forums/topic/390753-r34-gtr-v-spec/#findComment-6222250
yeah sold quickly probably because it was the first 34gtr to ask under 50k...
Couldn't agree with this more. I also think it is the actual price being realistic. Congrats to OP :)
https://www.sau.com.au/forums/topic/390753-r34-gtr-v-spec/#findComment-6236878
In all fairness there are a few R34s on carsales for less than $50K. IMO what set this car apart was the fact that it was:
a) bayside blue, which is always going to be the most popular colour after MPIII; and
b) a very clean looking car in the photos. Generally, the majority of R34s selling for under 50K don't look that great judging by the photos.
You can't beat that combination.
https://www.sau.com.au/forums/topic/390753-r34-gtr-v-spec/#findComment-6237665
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
