Hey guys/girls,
My r33 series 2 was leaking some liquid down by the passenger side feet area the other day and then my whole car overheated a few days after
steam going everywhere but i am pretty sure its not my radiator because when i got it towed home the next day i filled my radiator right up and left it runnig
for 20mins and water level did not change not sure whats going on with it any ideas?
My brother said it may have something to do with the heatercore but dont know?
Cheers
https://www.sau.com.au/forums/topic/390776-r33-overheating/
Your bro is right. Dash out job, & heater cores usually run around the $800 mark new. If your going to have a crack at it yourself, get a repair manual from Ebay ($10) & read up on it, especially when it comes to airbags!!!!
https://www.sau.com.au/forums/topic/390776-r33-overheating/#findComment-6221884
not a dash out job, you can pull them out from underneath the dash just pull the right angle elbows off them and they slide right out
there is a guuide here in the diy
300zx heatercores are the same, they are 250-300 each new from most radiator shops
https://www.sau.com.au/forums/topic/390776-r33-overheating/#findComment-6221924
Alright thanks for that guys i'll see what i can work out
cheers
https://www.sau.com.au/forums/topic/390776-r33-overheating/#findComment-6221955
Not a problem!
that way you can drive your car and gradually deal with the heater core... check out the for sale forum, there are guys that strip R33s occassionally and the core can be had for cheap
https://www.sau.com.au/forums/topic/390776-r33-overheating/#findComment-6222468
or quick fix for now, just loop off the heater hoses with a metal pipe.
worked on my Stagea/r34 wagon-apparently heater cores are about 60-80$ from Nissan & u dont have to take dash out to replace the core
check the thread in this link...
http://www.skylinesaustralia.com/forums/topic/375433-removing-heater-core-without-removing-dash/page__p__6172518__hl__heater+core__fromsearch__1#entry6172518
https://www.sau.com.au/forums/topic/390776-r33-overheating/#findComment-6230907
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
