Hey guyz
im thinking about getting a z-tune bonnet for my wait for it 34 GT. (dont hate on it its my car)
anyway on Ebay i have seen 2 that should be ok , what do you's all this what would be better
http://www.ebay.com....9#ht_2506wt_873
http://www.ebay.com....9#ht_2325wt_873
https://www.sau.com.au/forums/topic/390826-z-tune-bonnets/
there both totally different dont you notice one needs a gtr front bar the other one doesnt?
if u get the top 1 it will need gtr style front bar for gtt and youl need gtr hinges and mabey domething else
https://www.sau.com.au/forums/topic/390826-z-tune-bonnets/#findComment-6222699
wrong, they're both for GTT, the first link, second picture, is a GTT bonnet, and sellers listing states its for a GTT.
the seller should've been more clear and use GTT bonnet pictures only tho.
https://www.sau.com.au/forums/topic/390826-z-tune-bonnets/#findComment-6224340
if your painting it your obviously going to leave some CF showing yes?
otherwise there's no point in getting the CF covered one...
pics when done and report back on how you like the bonnet when the car is in the rain...
https://www.sau.com.au/forums/topic/390826-z-tune-bonnets/#findComment-6225533
I got my bonnet today will have it fitted on the 13th so ill post pics if it all goes will
and W34pongt why are you worried about heat on a 25GT anyway more just for the looks and weight reduction, right ? ....
because we all know the NON turbo 34s have SOO much heat I'm just saying :)
https://www.sau.com.au/forums/topic/390826-z-tune-bonnets/#findComment-6228340
It fits really well after I put in some rubber bits to make it sit flat the whole way, you can see it what i mean in the above pic's ^^ (before)
As for gaps its a really good fitting bonnet and I'm happy with it . I'll take some more pics to show you's all . for now enjoy some more photos :-)
things i did to make it fit well .
(1) front strut bar was taking off
(2) bonnet latch was moved up as it was not locking in
(3) lil rubber bits to make it sit flat
https://www.sau.com.au/forums/topic/390826-z-tune-bonnets/#findComment-6242731
  • 1 month later...
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
