Hmmm, well I'm all for mixing things up eventually but would like to stick to the same plan for at least a little while. Two different exercises plus adding weight to sit ups as Birds says gives a bit of diversity.
yes, i think that would also have been my main point to my suggestions, to give you some alternatives to situps alone. that is all.
  • Replies 241
regarding crunches...
While reading about shoulder issues I can across this...
Shoulder Saver #10: Limiting Traditional Trunk Flexion Work
Let it be known, the era of the 800 daily crunches is over. And, this isn't just because we're concerned about hip and lower back health; would you believe that you can actually screw up your shoulders with inappropriate core training? Here's what happens...
The rectus abdominus runs from your rib cage down to your pelvis; when it shortens, it pulls the rib cage down toward your feet. So, as you can imagine, if the rectus abdominus is tight, it can pull the whole rib cage too far down — making you look more like Quasimoto than someone who actually trains hard.
Beyond just the fact that poor posture isn't all that aesthetically appealing and actually makes you appear smaller, excessive kyphotic postures have biomechanical implications at the shoulder girdle. When your thoracic spine gets too kyphotic, the scapulae abduct (protract) so that they slide outward on the rib cage (toward your arms). This repositions the aforementioned acromion process, as the entire scapula becomes anteriorly tilted. An anteriorly tilted scapula dramatically increases the risk of impingement on those rotator cuff tendons.
How do we counteract this problem? As Mike Robertson discussed in detail in Core Training for Smart Folks, we need to prioritize exercises for the posterior fibers of the external obliques, as these exercises will posteriorly tilt out pelvis without pulling the rib cage downward.
And, by increasing the strength of these muscles, we'll take some of the burden off the rectus abdominus and shift things back into balance. When I see this problem, I drop all traditional trunk flexion movements (pulldown abs, crunches — and people should know to not do sit-ups by now) and replace them with pure stabilization movements (prone and side bridge) and "lower ab" exercises, most notably the reverse crunch.
Interesting article. I'll file it under the same section as "behind-neck pulldown and behind-neck military press are bad for the shoulders/neck/spine". 10 years later and I haven't dug them up, even with unrelated shoulder injuries.
FWIW I occasionally swap out situps for other exercises to mix it up and compare: seated crunches...leg raises...ab pulldowns...none of them have really produced results on par with situps, for me...particularly with the convenience of the exercise. 6 sets of 20 is pretty friendly on the hips / back, which I would say are only at risk if you're cheating / swinging your body and not pulling with your abs properly.
18/12/12
Sick with a cold :(
DB Press
10x2@5kg
10x2@6kg
10x2@9kg
Seated Row
10x2@60lbs
10x2@70lbs
10x2@80lbs
DB Lunges
10 each leg x1 @ 9kg
10 each leg x1 @ 12.5
3 each leg x1 @ 15kg - cut short due to wrist pain
Squats [email protected] to make up for it
Dead lift
10x1@20kg
10x1@30kg
10x1@35kg
Bicep bar curl
10x5@10kg
21x1@10kg
Lat pull down wide grip
10x2@40lbs
10x2@60lbs
10x2@70lbs
I've actually felt as though my core has received the most beating when using the ab crunch MACHINE. The only you sit in, adjust resistance weight, hold handles (usually above shoulders), and crunch. I've felt as though it wasn't so much targeting my abs when doing it with "too much" resistance - ie if I can set resistance to 40 and get 10 reps to feel burn in my abs, I'd set resistance to 55 and push for 8 reps. Reps done with too much resistance seem to lift your ass off the seat lol....
But yeah, doing this method really hammered core muscles more than abs...I know it's not a traditional or even logical way of doing it, but I can assure for myself at least, it works. Makes me feel like I'm going to shit my pants on the last few reps LOL
I used to use that machine and got amazing thickness to my abdominal wall. It really is awesome. Problem is (and this is going to sound retarded), I became too strong at it. I was eventually doing the whole stack of weight on the machine for 15-20 reps (friends couldn't even get one rep out of it)...with what felt like good form (you're braced in, so short of lifting yourself off the seat as you described, it's hard to cheat). It felt great for the abs/core, but after a while of doing it this heavy, I developed a "clicking" sound in my lower back that was a bit concerning. No pain, just a feeling not unlike knees cracking during first squat, but I thought f**k that! Been doing situps ever since, cause frankly, back clicks/injuries scare the shit out of me.
Seem to be on the exiting end of my cold which is good, yesterday was the worst. So glad I'm still able to work out even though I'm feeling a little ill. Exhausted though, about to have a nap!
DB bench press - flat
10x2@8kg
10x2@10kg
[email protected]
[email protected]
Lat pull down - Close grip
10x2@60lbs
10x2@80lbs
8x2@90lbs
6x2@90lbs
DB bench press - inclined
10x2@6kg
10x2@9kg
8x1@10kg
6x1@10kg
Tricep push down - straight bar
10x2@20lbs (9kg)
10x2@20lbs+3kg DB (12kg)
10x2@30lbs (13kg)
Sit ups
20x6 + 15 leg raises
Tomorrow will be my second full completed week, loving it :D
Edited by JEPPE
i have a back click too, it goes away the night after i squat and or deadlift, but the next day returns - most obvious when i do situps. very strange. no pain when it clicks EXCEPT if i'm standing and lean to one side, feels like a nerve is pinched.
Hooray, another week fully completed! Yay! Don't worry this will soon end and change to months. And this week I was even sick with a cold, gold star for me for effort.
Upped the dead lifting quite a bit tonight, awesome fun :)
DB shoulder press
10x2@4kg
10x2@6kg
[email protected]
8x1@10kg
Seated row
10x2@60lbs
10x2@70lbs
6x2@80lbs
10x2@40lbs
10x2@60lbs
10x2@80lbs
5x1@90lbs
Squats
10x1@20kg
10x1@30kg
[email protected]
Dead lift
10x1@30kg
10x1@40kg
5x1@60kg
Concentration bicep curls
10x2@4kg
10x2@6kg
3x2@8kg
24/12/12 - Nitro. Felt like tripe was feeling terribly sick and nauseous.
Bench Press - inclined
10x2@15kg db
10x2@20kg
10x1@25kg
6x1@30kg
5x1@30kg
Lat pull down - close grip
10x2@60lbs
10x2@80lbs
5x1@100lbs then 3x1@90
9x1@90lbs
Bench Press
10x2@20kg
10x2@25
5x2@30
Tricep push down
[email protected]
[email protected]
10x1@34
9x1@34
Leg raises
6x15
25/12/12 - Xplode
Did heaps better on dead lift today. Last time could only get 5 reps out of the max set, went back three times to try again and literally couldn't get it even an inch off the ground. Today got it to 15 reps and could have kept going but was getting faint. Was awesome improvement only since Friday. Will increase weight next time and see what I can do :)
DB press
10x2@4kg
10x2@6kg
10x2@10kg
Seated row
10x2@50lbs
10x2@70
10x1@80
6x1@90
Squats
10x1@20kg
10x1@30
[email protected]
Dead lift
10x1@30kg
10x1@40
15x1@60
Bicep bar curls
10x4@10kg
7x1@15
6x1@15
Gah. Forgot to do wide grip on lat pull down. OCD is making this difficult to accept.
Edited by JEPPE
Yay, today increased my max Tricep push down by 3kg :D which could mean anything really because the pulley is f**ked. Either way at this particular gym I stay on the same machine for this so it's consistent. Especially since last time I did triceps I had just increased it by 1kg which was huge after not even being able to do one rep at that weight about 6 sessions before that.
Bench press
10x2@20kg
10x2@25kg
6x1@30kg
5x1@30kg
10x2@60lbs
10x2@80lbs
6x1@90lbs - felt like machine was jamming
10x1@90lbs
Bench press - inclined
10x2@20kg
5x3@25kg
1x4@25kg
Tricep push down - flat bar
10x2@9kg
10x2@12kg (9+3)
10x1@16kg (13+3)
5x1@16kg
Sit ups
20x6
28/12/12
DB press
10x2@4kg
10x1@6
[email protected]
10x2@10
Seated row
10x2@50lbs
10x2@70
7x1@90
6x1@90
Lat pull downs, wide grip
10x2@40lbs
10x2@60
10x2@80 slight swing
Squats
10x2@20kg (accidentally did 2)
10x1@30
10x1@40
Dead lift
10x1@30kg
10x1@40
10x1@70
Bicep bar curls
10x3@10kg
10x1@15
Reps and sets are 10x2 unless otherwise stated
31/12/12
Not failing enough! Bench was a bit out of it because changed to DB and underestimated weight. Triceps improved a bit and added on some sit ups just to be cruel.
Bench press DB
7.5kg
10
12.5
60lbs
80
90
Inclined bench press DB
6kg
7.5
10
Tricep push down
9kg
13
16 (13+3DB) 10x1
6x1
Leg raises
6x15
60 sit ups
Oh, also tried wearing earbuds listening to music to see if it made any difference but unfortunately still got three approaches. This one made me laugh:
Dude: 'Hey!'
Me: *Takes out earbud* 'Eh?'
Dude: 'You're working pretty hard, that's great'
Me: 'Thanks'
Dude: 'What are you up to tonight?'
Me: 'Going out with my boyfriend'
***end of communication***
Srsly these 'polite' tees aren't going to work :/
Yah TTT, for work problems hey?
Haha, don't worry Leesh, apparently the gym I go to is particularly bad for this.
Didn't gym yesterday, skipped due to hang over and went today - ironically feeling worse. Felt weird and did my OCD in not doing my appropriate days but oh well. No nye for another 12 months.
2/1/13 xplode
DB press standing
4kg
6
7x1@10
6x1@10
Seated row
50lbs
70
7x1@90
8x1@90
Concentration curls
5kg
6
[email protected]
[email protected]
Lat pull down - wide
40
60
80 slight swing on final set
Tried 90lbs but form went out the window. Will add a 3kg DB into 80lbs next time.
Squats
20kg
30
42.5
Dead lift
30
40
70
Tried 80 and couldn't even get it off the ground, then underestimated and kept it at 70 when I should have increase at least a little. Was a bit dissapointed that I couldnt at least get one out at 80 but my grip was much more secure this time so at least some improvement was present.
And gloves are good but still don't save me from callouses around my middle knuckles. Or on my palms actually. Need bunny felt on the insides :3
my experience with gloves/callouses: when i first started without gloves, i got mad callouses - when i got gloves (harbingers, if you know them) I got even more callouses - but then they stopped after i got used to the gloves (near 2 months though). Now i'm almost callous-free.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
