  • Replies 241
Basically if my palm is facing backwards and I try to draw my elbow up as if it's being pulled up by a string with the forearm hanging loose, this is when it hurts. Can only get to about 45 degrees from my body before it gets tight and I need to stop. Every other movement is fine.
Turn your hand to have the thumb face down to the ground. raise the arm and put some resistance on the arm using the other one. If you feel some pain on the top of the shoulder you have the rotator cuff issue.
Rest and ice , is what you need initially as suggested. A good active release massage (which may hurt alot) and icing might see you right to go for a ride pending the physio's ok. depends how bad it is.
Yep it feels like that, although it's feeling even better than this morning. Have cancelled the track day anyway all your logics are correct :( Can comfortably do push ups but movement isn't free enough in general.
Guess this will be my weekly-break-every-so-often-during-gym thing.
What kind of exercises do you guys think would be safe? I think it would be good mentally for me to get back to the gym for a light work out or working out something completely separate. Are squats ok? Anything tricep/bicep/shoulder related that I could pull off? Will get to the physio and ask these questions as well but if the motion feels comfortable is it safe? Like I said push ups are easy. Need to go study anatomy, would like to know how the ligament is affected from different rom and if they are ok to use or not.
youtube "rotator cuff rehab"
there are plenty of band exercises to help.
Google images "rotator cuff muscles" - you'll be able to work out where you feel the pain and know which muscle it most likely is.
ICE when you can
The bands you can buy from lots of places.
Rebel has some near the gym section.. with the Yoga/Pilates shit - they are cheap.
Still go and train anything you can... as long as it is pain free.
Well, contrary to advice I'm currently in the hotel at Eastern Creek. Damn organisers wouldn't refund my track day even though there was only one vacancy and I had a very good reason. Couldn't stand the thought of handing hundreds of free dollars to them so drove up anyway. Turns out I'm almost fully recovered anyway, I think I freaked because every new injury I get seems like the end of the world when I don't know what it is or what will happen.
So there's going to be lots of wind and rain tomorrow, wish me luck :)
Hope you enjoy the day. It will be worth it for sure.
When you go back to the gym consider how important those small rotator muscles are and take some time to make them strong too. Lots of people hurt them ( including me in the past). But, this injury can be a great opportunity to tweak the muscle 'balance' in your weekly program.
Something else to add , if you don't already do it, practice 'scapular retraction' when you are doing pressing movements. It means pulling your shoulders back and down and holding them in place by squeezing the shoulder blades together. Hold this position when you are doing shoulder pressing movements. Why? because in this position shoulders are strongly stable.
You are going to keep getting better all the time , learning about your own body and it's limits. Then training out weakness.
22/01 Genesis Southbank
Military press
12.5kg
15
22.5 6.5x2
LPD wide behind
60lbs
80
100 10x1
9x1
Seated row
50lbs
80 10x4
Decline cable crossover
30lbs
40 10x4
Squats
20 10x1
30 10x1
47.5 10x1
DL
30 10x1
50 10x1
72.5 10x1
Bicep bar curls
10kg
12.5
15
26/1 chapel st
Bench DB press
9kg 10x6
Lpdcg
60lbs
80
100
DB inclined bp
8kg 10x3
9kg 10x3
Tricep push down
30lbs
40
50
Leg raises 15x6
Genesis Dandenong
Bench press DB
7kg
10
12.5
Lpdcg
60lbs
80
100
DB inclined bp
7kg
10 10x4
Sit ups 20x3
Tricep push down
20lbs
30
40
1/2 genesis Berwick
DB bench press
7.5kg
10
12.5
Lpdcg
60lbs
80
100
DB inclined bp
7.5 10x3
10 10x3
Rotor cuff exercise
20lbs 10x3
30lbs 10x1
Tricep push down
30lbs 10x1
40 10x1
50 10x1
60 10x1
70
Leg raises 15x6
Wrist curls
1kg 20x5
Edited by JEPPE
Also track day was awesome, was super wet and the fool mechanics put my wet rear on backwards which I rode my two sessions on. Was still a good day though the rain was actually awesome fun :) and my shoulder was perch by then!
Here's a pic
Didn't ride enough to see if my concentration or stamina has improved but was still a great into back. So much rain we had mud slides so couldn't ride!
Went to the physio today re shoulder and wrist which started hurting ironically from playing piano. He gave me additional exercises which I did today and are included above. Shoulder has definitely weakened in one movement but I'm glad I know what to do now to improve. Wrist is just a long term strengthening exercise and it's good for motorcycle riders too so I'm happy to include that.
Peace!
That's basically what I've been doing, as you can see I dropped the weight. It feels pretty much back to normal the only movement that is hindered is if I'm in a Barbie pose with my arms at right angles both facing forward and there is force pushing my hands together from the outside - then my left is much weaker than my right. My physio seemed to think continuing bench would be ok as long as there's no pain which there isn't. Am keeping an eye on it though and going slow.
It's good that you are thinking to take it easy it's a great attitude. But, if you are keen to recover much faster and completely consider my advice and a little extra research.
i have hurt my rotator quite a few times in earlier life and my physios at that time gave advise much like yours. "It's ok to bench etc.. as long as there is no pain.." The fact is rotator cuff damage occurs often without immediate pain feedback. Once damaged it continues to be more easily torn (it's already quite a small/weak muscle group).
The reason to completely drop the bench and pressing movements (as opposed to keep doing them) is two fold.
I give you the advice I reveiced from a professional athletics and sports physio . It was the last time I hurt my rotator cuff, it was the worst injury I had ever had but, based on this advice I recovered many mant times faster so hopefully your recovery will be faster too and you will avoid the recurring injury.
1) The pressing movements place the rotator cuff under stress, as they are recruited to stabilise. So this causes them to remain in a recovery state or may aggrevate the injury. (the rotator injury doesn't always give immediate pain feedback whilst it is actually being damaged)
2) Dynamic instabillity is the reason you got hurt.The relative weakness of the cuff muscles in relation to the pressing muscles you have been training is the main reason you have incurred the injury. You need to create a 'balance of strength in the shoulder. There is actually only one joint in the shoulder so ROM is completely stabilised by muscles.
Training the chest and other pressing groups in the short term isn't going to allow the rotator muscles the chance to catch up, strength wise.
I'm not wanting to create a crazy phobia about this injury, just help you cut your recovery time massively and give you some info to stop it ever happening again.
So, how do I work out when I can exercise it again? It happened a week and a half ago and stopped hurting after 3 days and now it has full range and doesn't hurt at my normal weights
This is weakness why taking a break on the press movements is recomended. I am sure it wasn't hurting right before the oringinal injury. So don't take that as a comprehensive green light. Strength and ROM should be normal. Retraining in the way that caused the injury is the last phase in the recovery. Weakness has it's cause in a reduction of muscle fibres / recruitment. due to the small tears the muscles expereinced when they were hurt. You have weakness, so best not to train as though you are 100%.
When that weakness goes away you are normal or at least both rotators are in balance. This weakness is what I would call the bad end of dynamic imbalance. Showing up as weakness in a pretty normal and lightest load movement, lets face it the barbie pose isn't a feat of strength. It means the tear in the muscle/s isn't yet full healed or recovered, to where they used to be. When it is, it will work like the other side does.
The reason people most often get this injury is because of dynamic imbalance and incorrect form (not using correct scapular retraction). Big strong pushing muscles and unmatched little shoulder girdle muscles under load = injury.
If you can modify your training to take this into account for the future , you far less likely to ever hurt it again. Also, you will have much better inprovements in the push movements strehgth to boot.
In terms of ROM. try these for a quick check too.
* Can you link hands when you reach behind the back with one and benind the head with the other?
If you are more than a fist away then you have some work to do. If you can touch then thats good.
* Shoulder flexion; Begin standing tall with your back and neck straight. Gently raise your straight arm forwards and up. At the top does your hand move to behine the head before you feel the stretch or before it.
Not trying to stall you on working out. Go for it on the legs etc.
Sorry if I am ranting a bit but, I'd hate to see you get hurt again.
Edited by rev210
Ok, so if I do these rotator cuff exercises to gradually strengthen the muscle is that ok? Obviously won't be anywhere near as hard on the muscle as bench press but then should be a little more up to standard with the other muscles once I get back into it.
Also what actual exercises can't I do? Is pulling ok? Can I do any shoulder exercise? I'm not that familiar with what actions affect certain muscles (thinking of taking an anatomy course actually) so an ABC123 explanation would be awesome if you can :)
You can still keep some shoulder movements, you need to activate them just not try to load them up till you are ready. I'd take that weakness on one side being gone (with full ROM) as your indicator to go back to 'normal' . Just having added some new excersises.
Rotator cuff and back work.
I had a quick google and these are some good ones for training (bit of anatomy in there too). But, there are also lots of youtube vids around I would guess for the how to as well.
http://www.t-nation.com/free_online_article/sports_body_training_performance_repair/cracking_the_rotator_cuff_conundrum
http://www.t-nation.com/free_online_article/sports_body_training_performance_repair/pushups_face_pulls_and_shrugs
http://www.t-nation.com/free_online_article/most.../my_shoulder_hurts_the_finest_whine
Cool, thanks for that!
Well in more positive news I'm pretty sure I'm ready to up LPD close grip to 110lbs without consequence on form, did a 7th set last night and finished the 10 reps with no trouble. Also triceps are getting a lot stronger as well. Can now see physical changes in triceps and abs and maybe a little in thighs.
Had a good day today, 10x75kg dead lift. Squats are still the same, could up them but was to perfect my form as much as I can and I know I can do better at the moment. Will eventually update my log!
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
