The other night i disconnected my ecu and left it all night. Reconnected it in the morning and tried to drive it down the street. It was barely idling, but i was able to rev it over 2500rpm. For some reason the boost comes on straight away whenever i go to take off. After a few mins i went home and i popped the hood to see the turbo blowing smoke. The temp gauge in the car was fine but the turbo was very hot. What should i do?
https://www.sau.com.au/forums/topic/39086-limp-mode-maybe/
Not sure exactly what you mean, it was barely idling - does this mean it was idling rough?
Boost coming in early could be because the ecu was reset.
If you have troubles with the idle, check the one thing you farked with - the ecu plug. That's where I would look first. Make sure its located properly, that no pins were bent etc.
Must ask, why did you disconnect the ECU? If you just want to do a reset, it is quicker and easier to just lift the negative terminal off the battery.
https://www.sau.com.au/forums/topic/39086-limp-mode-maybe/#findComment-793771
Boost comes on early and exhaust temps rise when your ignition timing is mega retarded
This is hard to explain
When i disconnected the ecu I meant I reset the ecu by disconnecting the battery... When I started the car is wasn't idling at all. The car will rev above 2500rpm but the boost comes straight away. I have to pump the pedle to get the reves up. Now I believe it is a timing issue.
When I removed the timing unit a few weeks ago the positive locating piece had broken off. So I believe my timing was out just barely. This wasn't a problem until i reset the ecu. when I reset the ecu I think it realised the timing is out and won't let the engine run properly. I can't think what is going on with the turbo tho???
https://www.sau.com.au/forums/topic/39086-limp-mode-maybe/#findComment-794200
It most certainly does explain what the turbo is doing, your firing the charge heaps later than normal which results in half your combustion taking place on the way out of the chamber and giving your turbs a nice big shunt as it goes through your exhaust.
Also explains your ultra hot turbine, manifold etc.
https://www.sau.com.au/forums/topic/39086-limp-mode-maybe/#findComment-795277
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
