post-22701-0-05828800-1328601645_thumb.jpg post-22701-0-77312200-1328601763_thumb.jpg post-22701-0-21616800-1328601816_thumb.jpg All parts from my 11/96 33 gtr that have just been replaced and all are perfect working condition ! front pipes $250 fuel pump $ 150 injectors $ 250 , also have a standard black intercooler in perfect condition from a 94 32 gtr let say $ 200 :cheers:
https://www.sau.com.au/forums/topic/390865-33-32-gt-r-parts/
Hi, is the front pipe an aftermarket piece with mandrel bends? Would it fit a r32 GTR
Thanks brad
yes it is aftermarket one ,i just replaced it with titanium one and will fit 32 gtr no problem
Where are you based? Are they any brand or Australian built? What are they made out off?
They were on the car when i bought it , i think they are jj ones that have been wrapped in heat wrap they are only about 3k,kms old , im near gosford or chatswood sometimes.
Pm me your number, I will meet you at chatswood Thursday for the cooler.
took it to work still waiting to hear back , dont care if you take it or not but a reply would be nice :thanks:
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
