Hi everyone,
I purchased my 1998 R34 GTT about 7 months ago, and all went perfectly for about 6 months. Recently I have run in to a few problems which I really need some help or recommendations on as to what might be the cause and what to do about it.
The car has a aftermarket alarm turbo timer immobiliser(not sure if it is all one unit or seperate) and a power fc which i think may be relevant to the problem, but also has aftermarket pod filter, front mount intercooler, and a few other bits and peices.
Problem 1:
At the end of a trip, when I turn the key to the off position, 90% of the time the engine will either turn off temporarily then try kick start(crank) itself, and when successful runs down the turbo timer and then turns everything off properly, or it will turn off (sometimes sound like its trying to start) but doesn't kick start/turn back on, but my boost controller and dash indiciation lights remain lit, indicating that the car still has power running through it and the car isn't actually off (I then have to turn the car back on by turning the key to the start position, then I can pull the key out with no problems everytime and it will run down the timer and shut everything off properly).
10% of the time it will actually stay running when the key is removed and run down the turbo timer then turn off with no problems.
This problem has gradually become worse, it use to be 10% failure rate, now its only 10% success rate of turning off properly.
I have also experienced funny business with the immobiliser where i can start the car and have it running (can't be done without the immobiliser disabled) then all of a sudden the car will sometimes beep or not beep and I put the handbreak down the drive and the engine cuts off.
Problem 2:
When driving with no boost, the revs can go as high as they want in any gear with no problems, when turning the boost on, in 1st-3rd gear, when excellerating and the boost preasure builds up especially getting towards the higher RPM, a squeel sound almost like some of the old kettles when boiling water or asif air is beeing squeezed through a small gap occurs.
Could this be the BOV, or piping, or any other suggestions?
Thank you so much for any advice in advanced.
Problem 1: Piss off the turbo timer thingo. You don;t need a turbo timer. If you can't wait 30 seconds to turn it off after you pull up, then you need a patience transplant. Timers are illegal* anyway, so who needs something unnecessary on their car that can trigger a defect when you could avoid it?
* It is illegal to leave an unattended car running. Turbo timers breach this rule.
Problem 2: You either have a boost leak (split hose, leaky clamp, broken weld, etc) or you have an exhaust leak (stuffed manifold, turbo or dump gasket, or possibly loose/lost nuts bolts on same or broken exhaust stud.) Find and fix.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
