Hello, congrats.
With my R34's - first mods i'd normally do are coil packs, air filter, exhaust and front mount. But everyones different and it obviously comes down to $ and preference.
In Melbourne, although I've never used them - I have heard 'Chasers' is good.
Full service, oils (engine,gearbox,diff), fluids (coolant, brakes,powersteering, clutch), , air filter (not a pod please) correct plugs, wheel alignment, then get it run up on a dyno to see if the fuel and shizzles is OK.
Work out what you want the car for, then work out your budget, then talk again to tuner and ask questions, be carefull, alot of dodge guys out there just want your money in their pocket.
Read all the threads in here, dont forget brakes and handling, this should be one of the first upgrades, a well set up car will be better than a car with more power but no brake or susspension upgrades.
Dont buy cheap tyres .
Only replace things that need replacing, dont buy things that will need to be upgraded again later if the power bug bites..
Which coil packs do u recommend ?
Is your spark failing, why do you need new coil packs, are you running over 25 psi.
If there not failing dont replace them for the sake of it !!!
Hey guys just purchased my first skyline! R34 four door gtt, was just wondering what my first mods should be and any checks I should do? Any info and decent people to deal with Melbourne would be great!
congrats mate! ive really got a soft spot for a good looking 34 4 door.
as said before, have a full service done, make sure the car is in perfect running order BEFORE you go modding it. otherwise its a massive backwards step. there are probably PLENTY of reputable mechanics in your area, have a look in the victoria section of the forum. to perform a full service, you dont necessarily need to take it to a performance garage for a full service, they can sometimes be very over priced.
Yeh well I pick it up next friday or my birthday, gonna do all the oils, spark plugs and filters my self, then take it in for a full check over, then do suspension, exhaust and fmic.... Then slowly take it from there
Your right, I should have been clearer. Check them first.
Personally, when I buy a car - if necessary I just do them the first time I do the plugs as we are talking about packs which are potentially 14 years old.
But again - it comes down to preference and condition, the packs in there may actually be fine anyway, or may have already been changed.
Edited by iwanta34gtr
1) Do a service.
2) Wheels (Good ones with sticky rubber)
3) Set of coilovers and dump it to the weeds (A decent set; TEIN, Cusco, Bilstein etc.)
4) 3" exhaust from the turbo back (Stainless)
:thumbsup:
Edited by Hank Scorpio
I totally disagree depending on circumstances. If the suspension hasnt been thrashed,shocks are still good and you want a comfortable ride instead of a bumpy go-kart then there is no problem with doing the usual mods and running 12 psi on stock suspension.
But yeah as said, Make sure you change every filter and fluid first and if you want to run a pod, make sure you buy a heat shield for it. Also if you want a buttload of induction noise from your pod buy a HKS Super Power Flow ;) lol.
Also post pics when you get it!
4 door <3!! :D
Considering the facts though the car was made between what? 1998 and 2001? This means that if it has stocko suspension still it is 11 - 14 years old. O.E shocks last (as a general rule of thumb) about 100,000kms so a car that has only done 10k a year on average is still going to have a 'decent' amount of kms on it.
Time to upgrade that suspension I reckon!
When I had an R34 GT-T a couple of years ago it had done ~130,000kms and the shocks were still 'acceptable', after dropped in some HKS coilovers though the car transformed itself!
Obviously all cars are different but due to the age of the vehicle and the fact that the suspension is still factory nine times out of ten I would look at replacing.
I helped a mate purchase a 1998 R34 GT-T Coupe with 148k on the clock and the suspension was great and i drove it on 14Psi. He only got Teins to lower it. Also my first 4 door 33 was a 93 model with 128Ks on it and even then the suspension was good enough to take 14psi. All im saying is "if" the suspension is still good, then in my opinion (permitting OP would rather a more comfortable ride) its ok to do the usual power mods as is.
No idea as to what else you should do other than a service, just got myself the same thing too.
I guess the vic thread, can help you alot, there's a post listing all the shops and there's some feedback on them too. Have learnt abit by slowly browsing through. Enjoy your ride when you get it :)
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
