Hey guys went to pits today, and got the two worst things, One, it was overcast and dark as hell, and two got some paki, who thought i was a little shit
here we go, i need to go for reinspection...
Tint - Replace or remove dark tint, if replaced not to be less than 35% transperent or reflective (he didnt check it, he just said yer its to dark, i thought they use a light meter or something)
Cracked Screen - Got a crack in the screen, has to be replaced..
Theres some oil leak on like something just above the turbo, not really a leak but just some oil there...
Exhaust - Was on borderline, but when de-celerate could be over....
He also said i could only get a permit for my Air filter (Its a pod)
and also write down it was honda prelude till i told him it was a silvia??
ok, but i thought you could get a permit for exhuast, BOV, and lowered suspension???
Can anyone help, i just need someone to rip off tint mainly, oh yer, is anyone sellin a front windscreen?
cheers
https://www.sau.com.au/forums/topic/39093-pit-results/
hey guys great news, i rang up DPi and asked about how they test it, they put me thru to a guy called john adn he said go down to where he is in midalnd and hell check it out, he couldnt use the meter on the windows, but he put a peice of paper inside and said yep i can see that, thats ok, and he also said bout the oil, he just laughed, and said just wipe it off,
he followd by the exhaust where he said just quiet it down, and he can give me permit for BOV, POD, exhaust and mayeb tint, i might ask next time i go, that he puts down, back half only.... cos thats only where it is, but tint the glass nyways and just have them down, when cop pulls you up....
but yer, so just need to get new windscren (which i had to do nyways) and put a silencer in the zorst (he said hell put down, quiet at examination)
but ohwell,
thanks
ps, anyone no a windscreen guy?
https://www.sau.com.au/forums/topic/39093-pit-results/#findComment-793789
there is a thread in WA about tinting. crank the search button.
the munted bracket by the drivers left knee is where the exhaust silencer used to be.
http://images.cardomain.com/member_images/...582_10_full.jpg
check around a few workshops who will probably have an abundance of these floating about, or call an exhaust shop and get them to fit an extra muffler to quieten.
look, Im trying to be helpful. I'm sorry you had a bit of bad luck, and it's good that you can call on advice from sites like this to get help with your car. that's ultimately what these forums are for...... but do you really have to post a new thread about every step in the saga on every ****ing performance forum in perth?
http://www.silviawa.com/forums/index.php?s...?showtopic=5574
anyone who would take a car to the pits with a broken windscreen and expect it to pass - and then blame it on the assessors race when it doesnt - needs a ****ing good slap in the earhole.
You're a young fella, whose excited about your car. that's cool, but FFS@!!
https://www.sau.com.au/forums/topic/39093-pit-results/#findComment-793848
alex does have a point..
however i think its kinda cool - i get to spend a lunchtime trying to decipher the text and the purpose of the post.
anyway...a little trick i have found when dealing with people who you need to suck up to for your own benefit - Go see them on a friday, people at work are always happier and more easy going on fridays. Believe it or not, but it works.
I wish i could understand at least a part of this:
... i might ask next time i go, that he puts down, back half only.... cos thats only where it is, but tint the glass nyways and just have them down, when cop pulls you up....
Otherwise get some legal tint or remove it ! always helps before going to the pits.
https://www.sau.com.au/forums/topic/39093-pit-results/#findComment-794762
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
