Hey guys looking to source a R33 gts-t (series 2) AFM, if anyone has one for sale, or knows best place to get one. Im on the Central Coast, NSW. Just looking to replace my one to see if thats whats causing it to stall every now and then, and also the dreaded flat spots. Not looking for a Z32 or anyhting just a standard one if possible. Cheers, Josh
https://www.sau.com.au/forums/topic/390959-r33-gts-t-afm/
I had that problem with my s2 r32 gts-t - really dangerous on the freeway too but dropping it into 2nd gear would shake the car enough (and the afm) so that it'd be ok again for a little while longer. Turned out to be dry solder joints on the socket. You could try resoldering them - worked for me :)
https://www.sau.com.au/forums/topic/390959-r33-gts-t-afm/#findComment-6223744
Here's an explanation in my parting out my car thread -
http://www.skylinesa...ost__p__5895893
Thanks mate , appreciate that .. i might give it ago, worth a try. So with the cealant, did you use anything in particualr to re seal it?
https://www.sau.com.au/forums/topic/390959-r33-gts-t-afm/#findComment-6223765
Nah, just left it as it is. I only cut 3 sides of the sealant so the remaining side kept it closed anyway so i didn't bother (i know, lazy :) ). I guess you can use any kind of silicon sealant.
https://www.sau.com.au/forums/topic/390959-r33-gts-t-afm/#findComment-6223842
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
