Does anyone know which SPL Pro Suspension parts are compatible with the Skyline ER34?
http://www.splparts.com/
I've called and email SPL over the pass 3 months. The rep told me he would contact the Australian distributor but never got back with me. I've also contacted other SPL vendors with no luck. Google isn't turning up any results either.
Edited by Bigalow
https://www.sau.com.au/forums/topic/390970-spl-parts-for-skyline/
How does that translate to the Silvia or Z32?
SPL parts only manufacture bits for USDM vehicles. If I figure out the complete compatibility list then I could purchase replacements for my stock components.
BTW, they at least told me that these parts fit the R32
"The following items will fit the Skyline R32 GTR:
S13 rear upper arms
S13 rear hicas eliminator (available but not advertised yet)
S13 traction rods
S13 rear subframe bushings or rear subframe conversion bushings
S14 rear diff bushings
S13 front tension rodsZ32 front tie rod ends w/ Z32/Z33 inner tie rods"
Edited by Bigalow
thats right.
you can get justjap adjustible arms or go the jap brands such as cusco and ikeya.
for local shit like whiteline & superpro, you can only get bushes but they only give very little adjustment +/- 0.5 degrees.
I'm very doubtful that I'll purchase Jap suspension bits. IMHO, most of the Jap suspension manufactures don't make components that are any better than lower priced bits from Oz or the states. SPL parts are Titanium with solid bushings. Which Aussie companies do you recommend? I'm interested in White Line but I don't know anything about them.
Lucky I found this thread!
We are the sole authorised distributor for SPL Pro Suspension Parts in Australia. Our prices are what I would call 'aggressive' - it will NOT cost you any more to buy from us than it would to buy directly from the USA.
I have not heard from the USA guys regarding your enquiry, so I will PM you now.
Please note we are also a distributor for SuperPro and Whiteline so we can help you with anything else you may require.
Pete
JDM Obsession Pty Ltd
Keep in mind front adjustable camber arms are sometimes made for people to set their cars up aggressively (i.e race cars, lots of neg camber), if you are looking to put more positive camber in the front the SuperPro poly adjustable bushes work very well (I should certainly hope so anyway, we helped R&D the damn things! :P)
Pete
Read and replied. You basically confirmed with Dori34 mentioned above, thanks Pete.
I do plan on tracking my R34 and I want to ensure I have the more adjustable suspension bits. SuperPro have poly bushings? I prefer to keep the suspension bushing consistent (i.e. all solid, all polly, etc).
Yes, SuperPro does all Polyurethane bushes. We sell lots of them and we all use them in our cars here at work. Very good product :)
Thanks mate but ATM I'm interested in SPL bits and finding R34 bits that have solid bushings to compensate the components that SPL doesn't manufacture for the R34.
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
