ok heres a basic question for anyone how has had anything to do with computers, ..
I have a Blitz Access in my R33 GTR with a Motec m800 running fuel ingnition etc,
the Blitz runs the idle control I believe ? this is what I need to mess with, how do I get into it and what do I need to do so, ( cables, programs etc ) ????
https://www.sau.com.au/forums/topic/390984-blitz-access/
you cant.
stock ecu would be a start with a nistune. in a r32 ecu with r32 02 sensors.
or, use the motec for everything. they dont come much better than a motec. or i will send you a plug in haltech platnium and you can send me your motec k thanx:)
https://www.sau.com.au/forums/topic/390984-blitz-access/#findComment-6224511
you cant.
I have just put A/C back in the car and now trying to sort out the idle pick up when compressor kicks in. ?
its got a hyper tune intake but still has the aac valve under the manifold, the Motec doesn't seem to control the idle so I would think thats controlled by the standard computer ( Blitz Access )
also, assuming the idle is through the Blitz, can't the idle be altered in there ?
https://www.sau.com.au/forums/topic/390984-blitz-access/#findComment-6226986
Rewire the motec so it does control the idle, the blitz access ecu is locked and scrambled and can only be tuned in japan by an access dealer.
https://www.sau.com.au/forums/topic/390984-blitz-access/#findComment-6227585
the m800 can do everything. it may of been installed that way for racing regulation regarding the standard ecu still being used.
any dyno shop should be able to patch in the rest of the motec to do the lot. my offer is still on the table :) should the quote be excesive.
dave.
https://www.sau.com.au/forums/topic/390984-blitz-access/#findComment-6228117
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
