Hi guys. I am currently making 250rwkw with no cat in the exhaust. How much power would i lose roughly by putting a 3 inch flanged 200 cell metal cat on it? All this police presence at the moment is making me afraid to drive my car! Cheerssad.gif
https://www.sau.com.au/forums/topic/390985-200-cell-cat/
Yeah and the assf**king that no cat gives the environment isn't that cool either. It shouldn't make a noticeable difference. And if it does, just add one more psi :)
https://www.sau.com.au/forums/topic/390985-200-cell-cat/#findComment-6224318
Get a venom 100 cell cat - power loss will be minimal.
Yep,thats what i am looking at getting. I just came across a 200 cell on a forum locally but he wants pretty much the same money as the venom one. I'll order one off George tomorrow. Cheers guys
https://www.sau.com.au/forums/topic/390985-200-cell-cat/#findComment-6224700
Yes true. Removing the cat/restriction can sometimes mean U can push the tune a little harder to net more results.
Question Is, is it worth it?
I found Some cars have huge potential without a cat, mainly due to a cheap or poor flowing cat,
Some may lose only 7 or so kw
https://www.sau.com.au/forums/topic/390985-200-cell-cat/#findComment-6225290
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
