Im looking at replacing a motor in one of my trucks, an iveco daily. New motor from iveco is about 15k, wheras buying one from china(where the iveco ones are made) is $5300 landed. Im 100% certain the motors are legit(Iveco parts have chinese labels in italian boxes).
The other options are to rebuild the motor only for between $3-5000, or buy a chinese motor locally for around $8k, however the new motors come compete with new turbo, alternator, loom, injectors,pump etc
I also dont really want the truck off the road for weeks whilst i rebuild it.
Does anyone have any experience with importing these sort of things, what i may be facing in terms of import duty, and dramas that i may face
https://www.sau.com.au/forums/topic/391007-importing-a-motor-from-china/
I have experience in the import export industry so I might be able to help you.Import Duty will likely sting you for at least 5% perhaps more, plus the 10% GST.
Motor cost including Shipping $5300
Import Duty $265
GST(10% of motor cost inc duty) $556.5
Total $6,121.5
Thats best case scenario. If you are seriously considering doing this I would reccomend talking to a shipping agent who can facilitate things like dealing with customs and more importantly find out if you need an import license or not (if you do need one it makes the whole thing one big hassle that is only worth it if your going to import goods on a regular basis.
  • 1 year later...
Importing motor parts and even motor vehicles from China to Australia is a common practice today as it is definitely much cheaper. However, there are certain rules that you have to know and abide to make sure all your efforts are not put to waste in the end. Australia accepts motor parts imported from China given that all documentation and permits are accomplished. You would also have to prepare a certain amount to be paid for import duty and tax rates. Do not be discouraged though as importing from China still proves to be far more reasonable today. You might also want to check out professional training and importing could turn out to be a viable business fit for you.
http://www.myimportlabel.com.au/import-from-china/
Import Duty $265
Total $6,121.5
He shouldn't have to pay any gst if he's buying it from a chinese company, only if he buys it via an australian company (which it doesn't sound like he'd be doing). Import duty's a given though.
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
