oh yeah i see,
so whats the deal with these cars of the future program?? how much is going to be controlled?
Nissan joining is good news for v8 supercars! i feel last few years has been a little boring. .
AFAIK, basic chassis ie; brakes, suspension and steering system, fuel system, trans, rear end, and obvious the frame itself is control. Engine is more or less up to the manufacturer, though there are obviously limitations.
Been a while since I bothered looking it up though.
Really this means nothing as far as the racing is concerned.. The cars are all the same underneath. Even the bodies, although they look different, have basically the same aero so even they make no difference. It's just somewhere to put the badge. Having said that this is a good thing if it means they keep changing the regs so that the dtm cars can race here.
And being able to cheer for a Nissan will be sweet :D
Could this be the motor they use??
The VK50VE is a 5.0 L V8 engine with 390 hp @6500 rpm and 500 N·m (370 lb·ft) @4400 rpm and redline is at 6800 rpm. Bore x stroke (mm) are 95.5 x 87.7 and compression ratio is 10.9:1. It has Nissans VVEL technology.
Why maxima they have 4 door skyline
If they made it 2 door all the bogans would complain its a gtr even if it wasn't
I hope they use the tactic what wins on Sunday sells on Monday and bring a rwd v8 into the country
Yep thats the idea steve...like GT500 in Japan but dont v8 supercars run a five litre?... hence using VK50Ve as a base.
VQ45DE is what was in the superGT car I think?...could possibly stroke that?
my detuning comment came from this
Motorsport
A flat-plane crankshaft version of the VK45DE is used by Nismo for Super GT races with the Nissan GT-R instead of using the GT-R's VR38DETT twin-turbo V6 engine.[1] The VK45DE was previously used in Nissan's 350Z Super GT car, replacing the previous VQ30DETT used in that car in 2007. In race trim, the Super GT VK45DE produces 500 PS (490 hp) and 52 kg·m (380 ft·lbf) of torque.[2] The engine idles at around 3500 RPM and is restricted to the above specified power output. Without such restrictions, the engine is reputedly capable of producing nearly 800 PS (790 hp).[3] Nismo reasons that by using the engine, they eliminate turbo-lag, save weight and generally prefer the torque curve of the atmospheric V8.
Source
@Martin - they do have on their rules page a 5.0 V8 controlled by Motec i would of thought half a litre smaller would of been ok but i guess if they got beat by a smaller engine all the teams would complain
http://www.v8supercars.com.au/technical/vehicledetails/tabid/1392/default.aspx
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
