Nissans To Pummel Holdens And Fords In The Supercars From 2013
Nightcrawler
 Share
oh yeah i see,
so whats the deal with these cars of the future program?? how much is going to be controlled?
Nissan joining is good news for v8 supercars! i feel last few years has been a little boring. .
AFAIK, basic chassis ie; brakes, suspension and steering system, fuel system, trans, rear end, and obvious the frame itself is control. Engine is more or less up to the manufacturer, though there are obviously limitations.
Been a while since I bothered looking it up though.
Really this means nothing as far as the racing is concerned.. The cars are all the same underneath. Even the bodies, although they look different, have basically the same aero so even they make no difference. It's just somewhere to put the badge. Having said that this is a good thing if it means they keep changing the regs so that the dtm cars can race here.
And being able to cheer for a Nissan will be sweet :D
Could this be the motor they use??
The VK50VE is a 5.0 L V8 engine with 390 hp @6500 rpm and 500 N·m (370 lb·ft) @4400 rpm and redline is at 6800 rpm. Bore x stroke (mm) are 95.5 x 87.7 and compression ratio is 10.9:1. It has Nissans VVEL technology.
Why maxima they have 4 door skyline
If they made it 2 door all the bogans would complain its a gtr even if it wasn't
I hope they use the tactic what wins on Sunday sells on Monday and bring a rwd v8 into the country
Yep thats the idea steve...like GT500 in Japan but dont v8 supercars run a five litre?... hence using VK50Ve as a base.
VQ45DE is what was in the superGT car I think?...could possibly stroke that?
my detuning comment came from this
Motorsport
A flat-plane crankshaft version of the VK45DE is used by Nismo for Super GT races with the Nissan GT-R instead of using the GT-R's VR38DETT twin-turbo V6 engine.[1] The VK45DE was previously used in Nissan's 350Z Super GT car, replacing the previous VQ30DETT used in that car in 2007. In race trim, the Super GT VK45DE produces 500 PS (490 hp) and 52 kg·m (380 ft·lbf) of torque.[2] The engine idles at around 3500 RPM and is restricted to the above specified power output. Without such restrictions, the engine is reputedly capable of producing nearly 800 PS (790 hp).[3] Nismo reasons that by using the engine, they eliminate turbo-lag, save weight and generally prefer the torque curve of the atmospheric V8.
Source
@Martin - they do have on their rules page a 5.0 V8 controlled by Motec i would of thought half a litre smaller would of been ok but i guess if they got beat by a smaller engine all the teams would complain
http://www.v8supercars.com.au/technical/vehicledetails/tabid/1392/default.aspx
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
