R32 GTR gunmetal grey duco, Overall good condition! Specs are as follows. Just over 100kms on the clock
ENGINE
R33 block (chemically cleaned, rebored and honed ground and crack tested, tunnel bored)
R33 crank, Crack tested, machined and balanced)
RACE series bearings
Forged Pistons & Rods
Rebuilt head (machined, pressure tested)
Tomei oil restrictior
ARP head studs
ARP rod bolts
7.5L sump with tomei baffel kit
Complete Tomei gasket kit
Gates timing belt
Tomei cams
OS giken cam gears
N1 oil pump
SARD 700cc injectors
K & N filter
Full stainless exhaust including 3" dump and front pipes (quite but nice note)
R34 BB turbos
Remapped ECU
New Fuel pump
Car is currently running standard boost
Running gear and Brakes
Extreme Clutch and machined flywheel
Reconditioned gearbox (with Receipts)
Slotted DBA rotors & new pads
Tein coilovers - standard camber tops
white line sway bars
Interior
Alarm / Immobiliser
Aftermarket Steering wheel
Torque splitter controller
RWD switch
TKO 300 kph + spedo
I am selling this car for a good friend of mine, i am dealing with all inquiries and test drives etc. due to his work commitments
I WILL BE DRIVING THE CAR, NOT YOU, YOUR DAD, OR YOUR HECTIC COUSIN
As i said overall the car is in good condition there is a few blemishes which are as follows.
-tear on drivers side seat
-slight paint fade on drivers door and boot
-repairs to ignition barrel need to be made after a recent theft attempt.
PRICE 17k Negotiable, will come with 3 months rego for the right price. I think this price reflects the car in its current condition.
Call Luke on 0437061618 after office hours, or text during office hours, Pictures are available via MMS just ask politely
We are also considering parting out the car, if you are looking to rebirth a written off gtr, or a complete engine package let me know. the car WILL NOT be split until a deposit for the engine or shell is received. SO DONT ASK
Interstate Transport can be arranged, at the buyers cost.
Cheers, Luke
Edited by lukeskidz
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
