News Break
The Australian V8 Taxi racing series will become a little less boring next year with the anouncement that Nissan will be racing in the series from 2013.
Hope they don't do too well or they'll be banned....again :nyaanyaa:
http://www.v8supercars.com.au/championship/newsarticle/official-nissan-to-join-v8-supercars-championship/tabid/70/newsid/12124/default.aspx
https://www.sau.com.au/forums/topic/391083-nissan-to-race-a-taxi/
It's good to see nissan back in mainstream australian motorsport, but don't expect a gtr to be racing.
with the 'car of the futture' setup next year, all makes will be running the same or near-same chasis, engine, running gear & suspenstion. The only thing that will change are the badges and the plastic body kits.
Exactly.
Aka NASCAR.
Which does produce some good racing.....its not uncommon to have to races, and 10 different winners while having 40 different race leaders.
As long as they dont start oval tracks...ill probably follow the sport lol
Cool!! bring it on..
The video says 'sedan', and 'nissan engine'.. So maybe it will be a V36 sedan with VQ45 or something?
Or maybe a v37? Who knows.. It will make things less boring thats for sure..
Not quite.
The silhouette (body) will be based on the Nissan Ultima. The engine will be a nissan factory design, however dont get too excited....it will be a 'complying' engine. That is to say it has to have 8 cylinders, it has to have xxxx displacement, it has to have no more than xxx hp, it has to run x fuel etc etc etc....so it will basically be an engine design equivilent to both the holden and ford are running now
so what your saying bard is that the engine designers at nissan require a full frontal labotamy just to be on the design team
No mullet, no job :P
guys.... nissan already make v8s.
it'll be a vh/vk50de or something like that
it wont be.
Yeah, because those engines are able to comply with the rules right?
negative.
The engine they will be using is a fresh desgin. Having said that, its VERY much based on what the category already uses.
negative.
You missed the sarcasm in my sentence Bradley. GAWSH. I already knew they weren't gonna get used :P
I knew it wasnt serious.....but other people on these forums are not as smart as you and I so just wanted to clarify...otherwise someone somewhere will run around telling his mates "i read on a forum......" etc :)
Fair enough then sir. As you were!
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
