Hi Folks,
I'm selling the bits in my garage to fund my trip to UK/Europe. So, I'd only swap parts for cold hard CASH - Don't bother offering swap for parts.
I have the following bits I need to sell;
1; Set of 4 R33 GTR wheels with tyres. I'll let pictures do the talking. Asking $1100 ONO.
2; Nismo Coppermix Twin plate clutch with flywheel, done 5,000km when I bought it, been sitting in box at my garage since. Asking $1500 ONO.
3; Standard struts for R33/R34 GTR, in good condition, passed roadworthy with these recently. Asking $350 ONO.
4; Complete standard exhaust system for R33 GTR Y pipe, cat, cat-back exhaust- great for clearing EPA and such. Asking $400 ONO.
5; Factory RB26 cam gears, in good condition. Asking $50 ONO.
6; Exhaust silencer for 115mm exhaust tip, in good condition with 2 bolts to secure it to the exhaust. Asking $50 ONO.
7; Pair of stuffed R33 GTR turbos, suit rebuild. Asking $100 ONO.
8; Pair of R33 GTR S1/2 Brake ducts (under the front bumper) In good shape. Asking $100 ONO.
9; Standard R33 GTR front bumper in Midnight Purple, would need repainting as there's scratches, with S2 lip and maybe with stuffed S3 lip as well No indicators and surround. Asking $200 ONO. - Can do deal with brake ducts.
I'm located at Doncaster East, VIC, small-ish bits I can send your way no probs - wheels, exhaust, bumper these I'd rather pick up.
I can be contacted by SMS on 0430 129 511 or PM.
Any questions, don't be afraid to ask. Again, only thing I'll swap these parts for cold hard CASH only.
Cheers
Grant
Hey,
An r33 box with near new exedy hd clutch, flywheel & tail shaft just sold on eBay for 1300.
Looking for a clutch & flywheel.
Interested depending on price, otherwise good luck.
Cheers.
Paul,
If you don't like what I'm pricing my items to sell you can either not reply or make me an offer. And your post is reported.
Shotgun the brake ducts!!!
can you pm me your number, i'll come up this sunday :)
btw would you happen to have the plastic undertray thats clipped on the lip?
Cheers,
Kev
Hi all,
R33 GTR wheels, R33 GTR bumper and brake ducts are SOLD!
Forgot to mention that the Nismo Coppermix is pull type (R34 GT-T, R33 GTR, and late R32 GTR '93/94).
Cheers
Grant
Are you kidding me?
Sure I'll offer you 1/2 & then you can have another go at me.
Grow up dude.
Paul,
Depending on price, I might. SMS me your offer, the number's on 1st post.
Bump, these stuff have to be gone, cos it won't be much of use for me...
Feel free to make an offer.
Also, front pipe is sold pending money clearance. Cat-back is still available at $200 ONO
After cleaning the garage, found some items I didn't realise I still have...
Standard Skyline 5 speed gearknob, Have seen quite bit of use - not perfect but. Asking $25.
R33 A-pillar trim, in good condition no holes at all. Asking $30.
R33 Ball joint assembly in pair, new in packaging (part no - 40160-05U00) Asking $100.
Will look into any offers for the clutch, and other bits, they're no use for me.
Thanks
Grant
Y pipe is SOLD and couriered. Standard Cat-back with compliance cat still available.
Buy them!
Buy them!
Buy them!
Buy them!
Buy them!
Buy them!
Buy them!
Buy them!
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
