I'm very keen, but I'm little worried about a very small oil leak I have (about 3 drops of engine oil every time I park).
I'll call the track tomorrow and see what they say, if its no worries, I'll pay tomorrow.
highly unlikly youll pass scruteneering at the start of the day :(
you still got 10 days, to fix it up mate, cant see where its coming from????
it may be 3 drops now but runninf at max temp could spit the seal right out and make it 3 litres and delay the fun for probly an hour.
its lots of fun mate i reccomend fixing it up and coming along :D
  • Replies 157
I would speak to the guys here running the day. It's not the track that will check your car its the SAU scrutineers.
SAU does the scruitineering on the cars. You'd be surprised that when you go to a speed off the streets day (or some other clubs) scruitneering works on an "HONOR" system. Personally, I have great peace of mind that the SAU boys look over the cars to ensure it is basically mechanically sound.
(Back on topic)
Have a look where it is coming from under the car. Might just be a drain plug washer or something simple. A few drops during a whole day of sitting isn't really too much bother from a scruitineering point of view, but if we look under your car and the whole underside is coated in oil then we probably won't give you a pass.
Mechanically you are responsible for your own car so you have to appease your own peace of mind if it is going to be ok.
Oh, and Martin there's no timing so we just put the cars into groups (a colored sticker on your car) there are no car numbers so run what ever you like :).
My father and I have pulled half the engine apart trying to fix the leak.
We've replaced all sorts of seals and shit trying to find it, no dice.
I've already done a track day with the car and it was fine, just the same few drops of oil every time we came in.
It really is just a few drops, I don't need to top it up between oil changes. And I won't have time to pull it apart again before the track day.
(The car is mechanically sound anyway, I use it every day for work, not the least bit worried about this damaging it)
Anyway, cheers for the feedback.
Knowing how little oil is coming out of it, do you think I'd get knocked back?
Again, thanks for the very helpful feedback
Edited by volityl
woohoo going to be a good day.
chance to test out the new timing system. (moving to an external 10Hz gps receiver)
and got the goproHD2 2 weeks ago so chance to test this out.
now just gotta get a wheel alignment and will be all set
I'll be coming. First time on Wakie with the 4 Door, so we will see how 'Sonic the Skyline' goes. See if he can go as hard as the old L98. Looking forward to meeting you guys there. I'll send in my form on tuesday. Paid for my NSW club membership today.
Cheers,
James
Just wondering Dave if you have received my entry form and payment.
cheers
Neil.
Paid and emailed entry form!
Paid and emailed entry form here as well
got it got it aaaaand got it
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
