So I have a 33 with no stereo at all.....I need to buy everything to get some abba pumping.....okay maybe more dubstep....My price limit will probably be no more then $1200 ..of course I love loudness and bass but I really appreciate crisp clear sound...can anyone point me in a direction of brands or setups? Thanks :)
https://www.sau.com.au/forums/topic/391156-stereo-setup-budget-of-1200/
what does the car have now , anything ?
depends on if you want to go further , after the 1200 , if so it changes the plan a lot
from scratch and not including labour
buy a double din deck , unless you have a pocket or cherish the little radios, stear clear of sony IMO the quality has slipped on the car audio stuff , Pioneer, Clarion, Kenwood , Alpine, are my first choices then the rest
buy some good splits, , Pioneer, Kenwood, Jaycar, Morel low end, Blaupunkt has some decent ones for 99 bucks I think,
so thats about half of the money already ? give or take the brands and features and install items
buy a sub , 10 or 12 inch, , , depending on your skills you can build a box , or buy prebuilt, but they sound average compared to custom box.
buy amp, depends on what your ultimate goals are , but start with sub amp, run fronts off deck power for now in most cases. Option Audio has some decent cheap amps, fusion, Boss mid series, Soundstream has some , Orion Cobalt, Rockford, Jaycar old heatsink type. US Audio is ok, on the cheap. as well as kenwood, pioneer, clarion, just no sony on anything
that would eat up the rest of your budget easy, dont forget 4ga amp wire kit as well, most mono amps draw a fair bit of power.
skip the back speakers at this point or use factory faded way out if you must
your kinda in a weird price point for a whole system unless you go cheap. and nasty . you can do it but you must hagle, and shop wisely to fit the price point
and if you want to upgrade later dont buy the wrong stuff the first time around
sound deaden the front doors, always !!!!! so budget that too, makes a huge difference in skylines
depends on what you call decent, ? you can if you shop right. and do most of the install or fabrication ,
and it depends on what you want in the end ? show car, sound off car or just music that sounds acceptable ?
1200 can buy you the last one , spent wisely and you roll up your sleeves and do as much as you can yourself . you can end up with a pretty damn good sounding system , wont be fancy brand names or mega loud , and crystal clear, but should beat the pants off any factory high end system and some" slap happy" higher dollar installs, expensive parts just slapped into a car for a quick buck
sound deaden doors is cover millions of times on here, MEA car audio, youtube, etc. google it and read and watch the videos
in this case order from usa on some of the parts now to save some cash, dollar is high now, and US markets are dumping stock after CES new stuff just came out, so bargains can be had , just watch out fro shonks and radios with features that wont work here. and shipping costs.
no GST or duty on things under 1000 bucks either
or buy OZ your call , save oz jobs if you can afford it
I want the clearest sound I can get , should I buy a second hand system? I heard a system in mums friends celica which was 3 grand and the sound was so clear and crisp....love it , maby I should go second hand?
Second hand can be risky, and can die the next day without warranty ? plus installers hate old stuff missing parts or not fit to the car
your not going to get the clearest sound you can get for 1200 bucks. buy some expensive headphones and audiophile cd player and disk if you want unreal clear sound. or sit live at studio
your idea of clear might be way different to mine,
clear bass ? or tight bass ?
clear voices ? could be titanium tweeters to hear the highs loud and clear, but hissy other times
cimbals clearly heard as the brushs sticks hit them, as above , or high end speakers, 5k a pair or more in perfect install,
silent system with no noise between songs is clear as well? super clean audiophile amp
or just the ability to get loud as hell and still be undistorted , different cars sound way different even with the same gear in it
you can get a parts a little at a time to build up to a outstanding system ? seriously you can dump more then 1200 on a deck alone
I've put in 50k- to damn near 100k system in parts and labour , so you do the math ?
I've put 500 bucks in cars too and they sounded pretty damn good, basic but decent, enough and still loud and clear
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
