Those didn't work. Depending on if you're on a phone or PC, you can click the add files button, select each photo one at a time (pick one photo, tell it to upload, click 'add files' again.) It sounds like a few things are unplugged, one is possibly the AFM (or wrong AFM) or the TPS. I've had the same issue before too leaving the temp coolant sensor unplugged, but that only became an issue once the car got hot. To know what the base idle is doing, unplug the IACV (electric plug to it), and see if it'll start up, and what the idle tries to sit at. It will be interesting if it can even start with the IACV unplug, and that would be a big clue too if the idle screw is set too low. Will wait for the pictures to load again so we can check plugs.
This has to be getting frustrating.... Is it all original wiring loom? Sounds like some more money needs to be spent on a new ECU/engine/sensors loom
Reputable and Body Kits don't normally go together, the industry is full of poorly fitting "kits" Noting your profile doesn't mention where you are in the world, Impul make the best kits I can think of.
I'm looking for a reputable bodykit company. I have a 2007 350gt sedan. Any help or if you can steer me in the right direction. Also any suggestions on what would look good instead of the stock standard front and rear bumpers.
I don't even know is those worked i can no longer see them
