Car Central Locking Won't Work And Can't Lock Doors With The Key Help!,
does it have a remote or is it on the keyhead ?
could be a few things
most likely the remote battery is low, or button worn flat inside. worth changing anyway, spend a buck a photo would help to identify the alarm or locking setup ?
blown fuse on door actuators
blown fuse on alarm or bad connection
no signal to brain on alarm , cut off antenna wire or bad reception
is it in valet mode , solid red light on car led or blinking ?
the alarm battery in the siren has nothing to do with it.
could be actuators slipping on the rods , no idea since you didnt mention what car its in ?
Edited by Carbon 34
Sorry it's in a series 2 33 gtst, n it's an aftermarket alarm that I have no idea what kind, came with the car, thanks heaps for your help anyway though, I tried both remotes I have n neither worked, I'll try n replace the battery as a start n see what happens, cheers
a photo of the remote might help ? identify it
more then likely if the doors lock while in the car fine using the door lock switch, its the alarm wiring is stuffed or fuse blown on relays interface.
could be a bad brain , since we dont know the brand ? nfi
has any work been done on the car lately ? battery disconnected lately or gone dead ?
L;ED on dash , blinking or always on ?
  • 3 months later...
