http://www.ebay.com.au/itm/800hp-Street-Legal-R33-Nissan-Skyline-Turbo-Drag-Drift-Race-/280823080195?pt=AU_Cars&hash=item41625c2503
Anyone know if this is legit? might buy it for the the running gear.... cheap drift car for the missus.
https://www.sau.com.au/forums/topic/391202-998-139mph/
Come on Trent surely you would know a coated GT35R isn't worth $9,000 like that ad says :laugh:
Then... 560rwkw with a GT35 on E85... lol... John Elliot.
New ebay user as well...
Maybe give Hills a call? Perhaps they know of the car if they did actually build the motor?
https://www.sau.com.au/forums/topic/391202-998-139mph/#findComment-6227482
HAHA boom didnt even see that... gonna blame my moving shop til 3am on that one....
delete thread for my blatant stupidity....
https://www.sau.com.au/forums/topic/391202-998-139mph/#findComment-6227534
Tell you will pay cash asap when he sends them.
Haha this is what I said:
Hi mate,
Could you please upload pictures of the 9.98 time slip, dyno graphs and receipts for engine work? I'm quite interested in your car as I've been looking for a project to come along for some time now; have got money ready to go and willing to pay far more than the current bid stands. I can see the money and effort that has gone into your car, but one can never be too safe, I've been stung before. Looking forward to your reply.
Thanks.
https://www.sau.com.au/forums/topic/391202-998-139mph/#findComment-6228273
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
