  • Replies 104
Hey mate
Looking for a 32 gtr tailshaft sent to Adelaide 5158? Really only need the front half as going to cut and shut for rwd conversion, cheers
yea mate got one 100 bux + postage for the front part
if you're still keen let me know and i'll work out postage
pete
Time for an update....
Sold items:
-Aftermarket castor rods
-Nissan tool kit
-Nismo metal gearknob
-Pivot 80 mm boost gauge
-R33gtst LED wing light
-S13 Corner indicators
-3 EGTs sold..... 1 left!
-Apexi Power FC
-Fibreglass bonnet
-Side Mirrors (white)
-Greddy strut brace front
-Raizin Volt Stabiliser
Still for sale!
-SAAS Steering wheel (no boss kit) $80
-Quick release boss kit $40
-SAAS gear knob $40 (as new condition)
-Wilwood 4 piston Superlight front brakes with Brembo 324mm drilled discs $1,100
Includes three brand new sets of spare pads, bracket adapter kit and braided lines
-Sony Xplod Stereo $40-Comes with remote control and manual
-M's turbo timer $40
-Apexi 2” Power Meter gauge $60
-Speco Meter 2.5" tacho $50
-Racetech oil pressure gauge $50
-Jetspeed EGT sensor/gauge brand new in box $50 now $40 cos it has a mark on the screen that won't come off from the 'protective' coating. Still perfectly useable.
-5Zigen tip $20 (pick up only, muffler is damaged but tip could be reused)
-Cat to muffler 3” exhaust pipe $40 pick up only
-Genuine Defi Link gauge set $1000 posted with insurance:
No I won't separate and yes this is the lowest I'll go on price. These are genuine Defi items, not bok choy China shit. Oil temp and pressure come with mount so you can just bolt on (fits Gtr and Rb30). Water temp comes with a mount to plug straight into Gtr. All sensors and an extra 2m link wire included as well.
Condition is excellent, used items have only been in the vehicle for approx 400km before removal.
Set includes:
80 mm boost (brand new in box)
80 mm tacho (used)
60 mm oil pressure (used)
60 mm oil temp (used)
60 mm water temp (used)
Defi Link controller (used)
Defi warning indicator light (brand new in box)
R32 Gtst (coupe and 4 door bits):
-Tomei 300km dash $300
-Custom strut brace rear $70
-Nismo control link set $550
-5Zigen 3”stainless steel turbo back exhaust $250 (from 4 door sedan)
-Intank Gtst fuel pump $80
R32 Gtr parts (Wrecked whole car so ask away even if it's not listed here):
-Rb26dett engine with good compression $2,900 includes wiring loom, ECU, intake, exhaust, clutch, everything to bolt in and drive away
-Intake kit including copy Greddy pipe to intercooler, twin pod filters $400
-Nismo rubber front brake air guides $150
-R32 Gtr N1 turbos, good condition $1,000
-Exedy Clutch, good condition $250
-R32 Gtr Garrett -5 turbos done approx 15,000km $1,500
-Greddy type R plumback setup $350
-Intercooler 600x400x100mm $150
-BOV setup including stock Rb26 BOVs (return pipe now sold) $200
-Gearbox in good condition $500
-Stock tail shaft $70
-Driveshafts $150 each
-Stock Rb26 front pipes $120
-Stock Rb26 exhaust manifolds and dump pipes $40 each
-Front hubs $150 for the pair
-Lower control arms $50 pair
-Attessa pump $100
-Brake booster $60
-Air con compressor $50
-Alternator $120
-Power steering rack $100
-Steering column $80
-Ignition barrel with key $50
-Indicator and wiper stalks $15 each
-Rear bar reo $170
-Pair of tail lights (gunmetal grey) $50 each or both for $80
-Pair of doors in excellent condition (gunmetal grey) $200 each or $350 pair
-Drivers door card, a couple of indentations where something has rested against it but otherwise perfect $50 (pick up only)
-Passenger front guard $100 no dents but a couple of scratches on the paint
-Front and rear windows $200 each (pick up only)
-Rear quarter windows $50 each
-Triple gauge cluster $60
-Climate control unit $40
-Stereo/console surround, has one crack but otherwise ok $30
-Sun visors $20 bux pair
-Kick panels $10 each
-Skyline door sill plastics $20 pair
-Fabric under bonnet trim $20
-17 x 9 +24 offset Modena rims (full set with rubber) $600
-Front lip $90, painted black has a fair few scratches, chips and a couple of broken clips (pick up only)
R33 Gtst parts:
-Hubs front only $150 or $250 front and rear
-Rear sway bar $50
-Rear cradle $100 (no brakes or diff, one bent control arm, includes hubs)
-Side skirts $80 pair
-Rear wing $80
-Passenger door $100
-Passenger side mirror $20
-Wiper stalk $15
-Passenger airbag $50 prefer pick up as I'm not sure how well it would go in post
-Front & rear seatbelts $20 each or $50 for all four
-Climate control unit $30
-B/C pillar trims $30 each or both for $50 (awesome condition)
-ABS unit $50
-ABS bracket $20 (or free if you buy the ABS unit)
-Power steering rack $50
-Pair of R33 Gtr rims with rubber $450
R33 Gtr (Black 95 non V spec model)
I've got a heap of parts left, pm me with what you need. I don't have front end stuff (except a drivers guard), gearbox or front seats but do have many other bits still.
R34 Gtr
-Rear hubs $100 each
S13/180sx (removed from a Sileighty) CHEAP!!!!
-5 stud hub conversion $500
-S13 body loom (from Ca18det) $50
-Speedo cable $20
-Front bumper indicators $20 pair
-Rear 180sx bar (white) $50
-Rear tail light garnish (the metal bit that goes between the bumper and tail lights) $20 or free if you buy the bumper
-Rear plastic garnish (the red plastic bit that has 180sx on it) $10
-Wiper and indicator stalks (a bit grubby but work fine) $10 each
-Earthing kit $20
-Unbroken radiator overflow bottle $20
-Locked diff with ABS $200
-Rear hubs $50 pair
Ill take the egt gauge, or 2 if you still have 2. Coming through valley heights tomorrow about 7.30 am, 7ish pm or 9.30 monday, whatever suits. Can you sms 0423 328 738
one left with your name on it mate
sms sent
pete
Tidy up of thread........
Sold items:
-Nissan tool kit
-Apexi Power FC
-Fibreglass bonnet
-Tomei 300km dash
Still for sale!
-Wilwood 4 piston Superlight front brakes with Brembo 324mm drilled discs $1000
-Racetech oil pressure gauge $40
Set includes:
80 mm tacho (used)
-Intake kit including copy Greddy pipe to intercooler, twin pod filters $320
-Stock tail shaft (rear part) $70
-Attessa pump $100
-Brake booster $60
-Alternator $120
-Rear bar reo $170
R33 Gtst parts:
-Rear sway bar $50
-Rear wing $80
-Wiper stalk $15
-ABS unit $50
R34 Gtr
-Speedo cable $20
-Earthing kit $20
-Rear hubs $50 pair
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
