Hey.
Just wondering if the RB26 sale falls through are you willing to sell the Head separately? and if so how much would you be after.
got a head for sale as well
2k for complete head including intake, exhaust, wiring loom etc
pete
  • Replies 104
Yeh man everything's in and running sweet, changed the main and big ends to be safe and tomei sump baffle.
If I need the sender I might come up for a drive and grab it from ya on the weekend
More stuff is gone but here's what's still for sale:
-SAAS Steering wheel (no boss kit) $80
-SAAS gear knob $40 (as new condition)
-Sony Xplod Stereo $40-Comes with remote control and manual
-M's turbo timer $40
-Speco Meter 2.5" tacho $50
-Racetech oil pressure gauge $40
-Cat to muffler 3” exhaust pipe $40 pick up only
-Pair of pod filters $30
R32 Gtst (coupe and 4 door bits):
-Custom strut brace rear $70
-Nismo control link set $550
-5Zigen 3”stainless steel turbo back exhaust $250 (from 4 door sedan)
-Intank Gtst fuel pump $80
R32 Gtr parts (Wrecked whole car so ask away even if it's not listed here):
-Apexi power FC with hand controller $750
-Custom catch can setup (two tanks, made by ProFabrication, only used twice) $300
-Exedy Clutch, good condition $250
-Greddy type R plumback setup $300
-Intercooler 600x400x100mm $130
-BOV setup including stock Rb26 BOVs (return pipe now sold) $200
-Gearbox in good condition $500
-Stock tail shaft (rear part) $70
-Driveshafts $150 each
-Stock Rb26 front pipes $120
-Stock Rb26 exhaust manifolds and dump pipes $40 each
-Front hubs $150 for the pair
-Lower control arms $50 pair
-Brake booster $60
-Air con compressor $50
-Alternator $120
-Power steering rack $100
-Steering column $80
-Ignition barrel with key $50
-Indicator and wiper stalks $15 each
-Rear bar reo $170
-Pair of tail lights (gunmetal grey) $50 each or both for $80
-Pair of doors in excellent condition (gunmetal grey) $200 each or $350 pair
-Drivers door card, a couple of indentations where something has rested against it but otherwise perfect $50 (pick up only)
-Passenger front guard $100 no dents but a couple of scratches on the paint
-Front and rear windows $200 each (pick up only)
-Rear quarter windows $50 each
-Triple gauge cluster $60
-Climate control unit $40
-Stereo/console surround, has one crack but otherwise ok $30
-Sun visors $10 bux pair (a tad dirty)
-Kick panels $10 each
-Skyline door sill plastics $20 pair
-Fabric under bonnet trim $20
-17 x 9 +24 offset Modena rims (full set with rubber) $600
-Front lip $90, painted black has a fair few scratches, chips and a couple of broken clips (pick up only)
R33 Gtst parts:
-Front hubs- includes uprights and abs sensors, no lower control arms $100
-Rear sway bar $50
-Rear cradle $80
-Rear wing $50
-Passenger door $700
-Passenger side mirror $20
-Wiper stalk $15
-Passenger airbag $50 prefer pick up as I'm not sure how well it would go in post
-Front & rear seatbelts $20 each or $50 for all four
-Climate control unit $30
-B/C pillar trims $30 each or both for $50 (awesome condition)
-ABS unit $50
-ABS bracket $20 (or free if you buy the ABS unit)
-Power steering rack $50
R33 Gtr (Black 95 non V spec model)
I've got a heap of parts left, check out my wrecking thread:
http://www.skylinesaustralia.com/forums/topic/389332-wrecking-black-1995-r33-gtr-fatz-strikes-again/page__pid__6286473__st__120#entry6286473.
I don't have front end stuff (except a drivers guard), gearbox or front seats but do have many other bits still.
R34 Gtr
-Rear hubs $100 each
S13/180sx (removed from a Sileighty) CHEAP!!!!
-5 stud hub conversion $500
-S13 body loom (from Ca18det) $50
-Speedo cable $20
-Front bumper indicators $20 pair
-Rear 180sx bar (white) $50
-Rear tail light garnish (the metal bit that goes between the bumper and tail lights) $20 or free if you buy the bumper
-Rear plastic garnish (the red plastic bit that has 180sx on it) $10
-Wiper and indicator stalks (a bit grubby but work fine) $10 each
-Earthing kit $20
-Unbroken radiator overflow bottle $20
-Rear hubs $50 pair
-Locked diff with ABS $200
-Nismo 2 way 4.1 5 bolt $650
Sold items:
-Rb26dett engine & N1 turbos
-Wilwood 4 piston Superlight front brakes
-Aftermarket castor rods
-Nissan tool kit
-Nismo metal gearknob
-Pivot 80 mm boost gauge
-R33gtst LED wing light
-S13 Corner indicators
-All EGTs
-Apexi Power FC
-Fibreglass bonnet
-Side Mirrors (white)
-Greddy strut brace front
-Raizin Volt Stabiliser
-Apexi 2” Power Meter gauge
-Jetspeed EGT sensor/gauge
-Tomei 300km dash
-Nismo rubber front brake air guides
-Pair of R33 Gtr rims with rubber
-Side skirts
-5Zigen tip
r32 gtr radiator overflow bottle?
r32 gtr fuel level sender?
need both, posted
thanks
crap i forgot to reply to your pm
yea will be 125 posted let me double check tomorrow to make 100% sure i have the overflow bottle
cheers dude
  • 4 weeks later...
Hi mate looking for some r32 parts.
r32 gtst abs tail shaft
any parts that will help me with my r32 5 stud conversion
a indicator / hi low stalk
r32 gtr fuel pump
and a lot more if you can help
thanks toby
r32 gtr fuel pump
thanks toby
only havea non abs tail shaft $70
have a full 5 stud conversion $200
have a 32 gtr indicator stalk $40
r32 gtr fuel pmp and sender $130
yea ill proabably have more just pm me
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
