Got a few parts for sale.
Apexi Power FC + controller
Suit R32/33 GTR
Works perfectly fine used it on my gtr for a few months
Standard tune setup
$850ono
Apexi Boost control kit
Suit a whole range of cars; knows it works on R32/R33 GTR
Holds boost great, was used with the above power fc
$250ono
OR $1k FIRM for all apexi gear
Exedy "Sports Tuff" Heavy Duty clutch kit
Brand new in the box with all the gear required
If bought in SA will throw in 4L of Redline Shockproof for $80
Part number: NSK-7172HD
$620ono (Cheap)
PM or msg me on 0423284832
All in SA happy to post at your expense.
Do u have the box and model number for the boost kit ?
no box I bought it off a fellow SAU member.
it plugs into the factory solenoid plug and has a 3 "prong" plug that connects to the power fc
the product number would be this: 415-A001
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
