Ok so wasn't happy to find my compressions are as follows (front of motor back)
130
130
130
112
112
112
Rb20 det
Is my head stuffed? I'm assuming so, is it easier Bette to get a new head of have mine reconed? How do I find out exactly whats wrong with it so I don't waste time ad money?
https://www.sau.com.au/forums/topic/391253-low-compression/
Assuming you've not got issues with timing or bent valves, it may be just a very tired motor with rings that are badly worn.
Other than low compression, are there any other symptoms or problems noises? coolant in the oil? oil in the coolant? lots of moisture/water coming out the exhaust? If you lift the oil filler cap is there milky crap on the underside?
If its a reasonably stock engine, go for a wrecker motor. It may not be worth rebuilding. RB20 wrecker motors are cheap. its probably a good opportunity to do an RB25DET conversion.
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6228455
Oil is clean coolant is crystal. Nothing out the exhaust.
Plent of mods
1bar boost
Td05 gtr injectors coilpacks Nistune. Claimed 210rwkw an only 120.000km so probably a hard life from the last owner (who didn't build the car)
Backfiring on high boost soni have removed the boost controller and running .5bar
Where do I start diagnosing after a simple compression test?
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6228574
Guessing you did the test by the recommended method - engine up to temp, throttle wide open.
Repeat the test, this time adding a small amount of engine oil to each cylinder. If the compressions improve, then you have worn rings. If not, then it is likely worn valves. If worn valves, get a leakdown test to point to inlet or exhaust or both valves.
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6228623
to be honest its just a tired motor as said above, but it doesnt mean you need to do ANYTHING.
if its not burning oil or mixing things where it shouldnt be, just leave it alone. main thing is that its consistent, not ONE bad one showing theres a serious issue... when they are all consistent it shows the motor is intact but a little worn.
years ago my best mate had a CA that was abit like that (only worse).. He put a disco on it, boosted and tuned it to a good 190kw, thrashed it for ages, sold it to another mate who put slicks and a locker and ran a 12, who then sold it to a friend of a friend who competetively drifted it for another 4 years (evidence on NS if you really need it) and then sold the CA to a bloke with a dato in working condition (literally nothing wrong). drifter boy put an SR in it............. 3 of them to be exact within the first 12 months.
so yeah. unless ur pedantic dont worry about it.
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6228645
engines are the most FORGIVING part of a car and you really need rough as guts to hurt them.
even though compression doesn;t look too crash hot more than likely she will keep on going for a very long time! as thats what they are designed to do
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6228674
Also I have done most of the basic things already to address the misfire unsuccessfully. That's why I aspects maby the head, also why I turned the boost right down.
So theirs no easy way (unless it's rings) to freshen up the head?
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6228775
This is what you need to do:
1. Ignore all the posts above. Using oil can mask valve issues as well.
2. Get a "Leakdown" test done. This is where they bring each cylinder to TDC, and take the spark plug out and put in compressed air.
3. Remove oil filler, radiator cap, all spark plugs. Handbrake up, out of gear.
4. Rotate engine to bring first cylinder to TDC firing and inject compressed air into sparkplug (continuously) using a compressor.
5. If air blows out the rocker vent / dipstick / you have f*ed cylinders/bores/rings
6. If air blows out of coolant, you have head gasket problems or a cracked head
7. If air blows out of inlet side, you have bent/worn inlet valves.
8. If air blows out of exhaust, you have bent/burnt exhaust valves.
9. If air blows out of an adjacent spark plug, you have blown gasket (or air is coming out from valves being burnt/bent, but u will hear it in the pipes as well).
10. repeat for all 6 cylinders.
if the results are consistent, the you have a consistently worn engine. So go looking for fuel/electrical issues.
if you have one pot with stuck valves, then that will create misfires.
If al the above looks good, you should also look for a stuck PCV valve and blown gaskets around the throttle bodies. you should be able to hear a pfft pfft noise...
Good luck.
BTW I made my own leakdown test fitting. Brazed a compressor fitting onto the bottom half of a spark plug..
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6230558
Very interesting I will try that when I get the opportunity.
I did have the chance to do a wet compression test today.
For a start I got a new battery. My figures may have been skewed by my old battery. (we needed to piggy back it and. Have it out cos it would only hold up properly to 3-4 cylinders before flattening)
So new battery
The test we performed a few times
These are the figures for the three runs front to back of motor.
These arethe test results...
-Dry test a few weeks ago -old battery-
-Wet test
-Test again no more oil
-Yet again no more oil
            Dry.    Wet1.   Wet2.   Wet3.
Cyld  1 - 130.    140.  140
Cyld 2- 130.    135.   135
Cyld 3 - 130.   132.  131
Cyld 4 - 112.   115.  120  125
Cyld 5 - 112.     125.   135
Cyld 6 - 112.     145.  145.   135.
I retested the lowest and heighest again.
I have noticed a bend of figures lowering in the middle so it seems to me to be a banana head
The 112-145 I'm hoping I a testing issue...
The only blackened spark plug again was no1 consistantly blackened?
Edited by GH05T
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6231266
I dont think your compression is that bad , my brother used to have a rb20det out of the r31 and that have about 150psi in most cylinders ,
you could put a new set of rings on or convert to an rb25, sounds like your coilpacks need replaced, you should still be able to run a bar of boost even with worn out motor.
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6232039
But those figures, do they suggest a warped head? Seing as the figures bend... Lower towards the center?
I think I will get a proper leak down test next. See what that returns
Edited by GH05T
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6232441
if you have the ability and time, you could take the head off and have it checked and have a bit shaved off , that would raise the compression by itself, take half a mm or 1mm off and you'll up to over 160psi or more
but if it were me id get an rb25, check the compression , then you'll be on another level and more potential obviously
i wouldnt waste money on a 2L.
https://www.sau.com.au/forums/topic/391253-low-compression/#findComment-6232838
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
