Ok so at idle im getting a bit of smoke, nothing major but a constant little puff. kinda like condensation, but its always there.
But, as soon as i let the car idle after a drive and hit boost, it starts to really smoke. it never did this at all untill a few days ago.
its oil smoke, i know that because its blue and smells of oil. What im worried about is that it could be the turbo oil seals gone, and i got quoted $800 for a turbo overhaul for a Trust TD07. I can get the head reconditioned for half that price, getting new valve seals if they are the problem.
What I noticed the other day though is a oil leek from the top oil feed to the turbo which looks like its been there for a few days (about the same time since this problem has started), could this be part of the problem, or even better the problem itself (but i doubt it)?
the problem is that im not actually near the car untill next week, so im trying to do as much research into this as i can so that i can get straight into what the suspected problem when i can.
Could it be the turbo oil seals, the turbo lines blocked or leaking (feed or return) or the valve seals leaking?
any info into this would be greatly appreciated as I want to get straight into this asap.
cheers
oh, the engine is an FJ20 if that helps. Out of a DR30
https://www.sau.com.au/forums/topic/391272-i-hate-smoke/
I thought blue smoke was oil going past your seals, valves piston rings etc and white smoke was blown turbo seals or failing turbo?
I had white smoke from f**ked piston ring on cylinder 6 on my old RB25DET.
https://www.sau.com.au/forums/topic/391272-i-hate-smoke/#findComment-6228828
Using the wrong oil can cause oil consumption and blue smoke. fresh engines have good compression, and fully synthetic oil is good to use. where as more older engines that are a bit tired, thinner fully synthetic oil can get past the valves and seals and you get oil consumption and blue smoke. Check what oil you are using and its viscosity. You could try using semi synthetic if you are not already.
And yes get a compression test.
This exact thing happened to me in one of my evos in the past.
Edited by HYBR3D
https://www.sau.com.au/forums/topic/391272-i-hate-smoke/#findComment-6229743
Ok I'll do a compression test later on tonight.Imusing 20W50 mineral oil, as that's what everyone recommends because of the engines age. I have no idea what oil was in it originally
I would be trying a 10w40 semi synth, unless the engine is built with loose tolerances.
White smoke is usually coolant leaking into the cylinders, perhaps the head gasket is gone or the turbo is leaking internally? Compression test time.
https://www.sau.com.au/forums/topic/391272-i-hate-smoke/#findComment-6230296
Would I get any benefits going to that oil though?I guess headgasket could be a possibility, but car still pulls hard and there's no oil in the water or water in the oil.Couldn't be the turbo leaking water as its only oil cooled. I dont know if I've mentioned but it's s trust td07
https://www.sau.com.au/forums/topic/391272-i-hate-smoke/#findComment-6230472
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
