I've been interstate for the week, and the car has been sitting. Come home and it's flat - opened up the battery to see exposed plates, my bad! Topped it up yesterday and chucked it on the charger, Reckon it got about 6 hours last night and another hour or so this morning.
Went to start it - no go. Looked at the power guage, and it was showing just over 6 volts. Chucked the multimeter on the battery terminals and it was around 11.5v. How accurate is the power gauge in the car? Reckon the problem is actually the battery?
https://www.sau.com.au/forums/topic/391312-m35-volt-gauge/
I'm not sure how good the power gauge on the stagea is but I'd say your battery is farked, I found exposed plates in my wifes car (merc) and topped it up but ended up replacing the battery a few weeks later because it wouldn't hold a charge any more. I too saw a decent reading off the battery with a multimeter but as soon as I put any load on it by cranking the volts just fell away and it wouldn't start.
How old is the battery? Any swelling on the sides?
https://www.sau.com.au/forums/topic/391312-m35-volt-gauge/#findComment-6229081
11.5 volts still isn't enough for a battery in good condition; I'd say she's rooted.
When mine started to get that low; it started throwing airbag faults and CEL faults. Replaced the battery, reset the faults; all was fine.
https://www.sau.com.au/forums/topic/391312-m35-volt-gauge/#findComment-6229116
Ok so, This similar thing happened to me
1st time I didnt drive my car for about 4 days. JUST sat there. went to start it. no dice... I just jumped to the conclusion stock battery was f**ked and got a new one.. started fine...
Then recently, I didnt drive it for about 4 days again... Didnt start. took a lil portable jumpstarter with me for 1 day and had to jump it everytime...
I thought it was weird because i got a multimeter on it and it was showing 12.9 volts.
Decided to loosen the terminals... remove them off... Push the brake to take out any excess charge in the car... and reconnect..
STARTED FINE!!!
must be like some gay as hell immobiliser? or something?
If you still have your old battery it would be good to see if you tried it, if it would work since its bee removed!
https://www.sau.com.au/forums/topic/391312-m35-volt-gauge/#findComment-6238441
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
