Hey guys so I got 2 issues that just came about when I put my 2nd hand radiator in.
1st. It has hoses on the bottom of it for power steering I have just left these as my car doesn't have hoses running to power steering from the radiator.
This wont cause any issues will it?
2nd. The outlet from my engine to my radiator is rusted so badly now when I tried to clamp it back up it just crushed and leaks.
I now have no where to connect the hose from my radiator to. Ideas please?
All I could think of doing was pulling the whole thing out and taking it to get a little section of pipe welded onto it.
https://www.sau.com.au/forums/topic/391335-radiator-rusted-pipes/
damn thats some bad corrosion. i would suggest doing what you mentioned and remove the intake manifold or it should be possible to get it welded while its still on the car. you'd just need to make sure everything was covered up well. with regards to the 2 hoses coming out they would be for the transmission cooler for an automatic r33. i take it yours is a manual? then just plug up the 2 holes.
Yeah my car is a manual.
Do I have to plug them up or can I just leave them to drain then leave it alone?
I might go talk to a radiator place on monday or go to a welder and see what he thinks about doing it in car.
Glad I caught this early because I would hate to have this pop doing 100km down the highway
They are a press in pipe, and your auto cooler lines dont 'need' plugging as long as they are never going to be needed again. Id just cap them with something maybe put a bit of fuel hose joining the 2 pipes.
nope, rip it out, if its easy enough, machine up (or get machined) a s/s pipe that replaces it
To weld it would be superficial if your welding to rusted already very thin tube. or rip it out and tig on an alloy tube. i like the s/s pipe idea better though. Never rust again!.
Your block wont be that rusted, cast iron rusts hardly anything compared to mild steel rolled tube. will still be a bit rusty but ok. Get a good coolant and run a bit of castrol RCI (radiator and corrosion inhibitor)
Great thanks :D
Might see if anyone is wrecking a 33 and I could just get a whole new one for like $20
If I cant then I will price up a s/s one
Thanks for the help guys
I will have to get a mate around to help try work out if its all earthed correctly
  • 1 month later...
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
