HI guys, I have recently got my R33 rb25det ecu changed, it now runs a Z32 ecu + nistune, I have only had it done for about a week. have a few things to clear up before I go ahead with a tune! need a few answers first in regards to TUNING.
First of all, what does a tune do it corrects fuel/AFR/timing etc? will it correct my R&R issue, will it correct my economy, will it help with cold starting and high rpm issue?
I hear most nistunes tuned properly have a massive difference over the stock ECU, I run r32 actuator, FMIC & 3in turbo bk exhaust. - am hoping I dont need AFM or anything when I for the tune?
I have chosen WILLALL to do the tune, just have to get a few things done by mech asap before the TUNE :D
hope someone can provide some assistance to a new guy :)
cheers
https://www.sau.com.au/forums/topic/391375-specific-tune-queries/
I got told a tune can fix lot of stuff in your car because the tune makes it all run right with all the mods that have been put on to the motor so there for the tune makes it all run right and i think the tune can found out if your car is not running right like if something is broken :thumbsup:
:) I am hoping exactly that..... to fix everything... ive had the car 6months and this whole time its been running R&R and sluggish and cold start, will be good to finally have its FULL POTENTIAL :D after the tune :P
It won't fix *everything*.
If you're having cold start issues already then it would be worth looking over the car, Japan has snow.. Much colder than here, the car is built from factory to be able to start in the cold.
"High RPM issue", I'll take a stab and guess you're having misfire in high RPM? Also not likely to be fixed by a tune, coilpacks are a common cause for this, also check plugs.
R&R, yes it will help with this, however an r32 actuator should be getting you 10psi if hooked up without a boost controller, as far as I'm aware most 33's can take 10psi (including mine) without R&R unless there is an issue with the AFM.
A tune will help with economy and power, especially with the change in boost levels, it can also help diagnose what other sensors etc might be faulty and causing troubles.
Take it up with willall since thats who you want to do the work, they'll be able to give you the best answers :)
Take it up with willall since thats who you want to do the work, they'll be able to give you the best answers smile.gif
Thanks, I understand some of what you're saying, and Yes I will be going to WILLALL asap to see what they say :P just abit nervous, last thing I need is to have to change a bunch of things before I can even do the tune! as you say maybe plugs, maybe AFM, etc
But I will find out asap,
cheers
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
