Hi everyone,
I want to upgrade the exhaust on my 97 model GTR, currently it only has a 3 inch pipe from CAT back into nismo rear muffler.
I find it drones a bit on the freeway which I hate. I want something that doesn't drone but once you hit boost the amazing sound of the RB26DETT comes to life.
Any recommendations from Turbo back?
Thanks
Engine is completely stock. I just don't want it to drone on the freeway, but still have some loudness about it.
budget: Any.
was thinking of upgrading the dump pipes, high flow cat then rest of the exhaust.
I've heard some GTRs and they sound awesome.
My friend that has a R32 GTR (everything stock on engine bar FMIC) has a Fujitsubo 3 inch and sounds awesome. I think dumps are Tomei. The rest is Fujitsubo.
Hi-flow cat, too. But in saying that.. I think HKS Superdragger sounds tough.
i just replaced my dump and cat with 3.5inch hiflow and now the exhaust sounds alot better, fujitsubo 3 1/2inch catback, same muffler but now its not that quiet anymore lol
mine might be up for sale soon
custom made 3.5" stainless steel from cat back with rear cannon muffler (3.5" id).
have a cat somewhere for it too. think it's a 3" cat that is flared to 3.5" to fit the rest of the system.
i think it sounds great but my front/pipes are not standard...nor is the engine.
What is this coming off of? I love the idea of a nice, light titanium system.. But the sound is a little... "tinny" for me. At least, the few that i have heard.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
