Intermittent Misfire?
MAS_R33
 Share
Hi guys.
Ive just got my car back from the shop where they installed a gcg high flow and did a tune.
The car runs amazing, with only one minor problem.
When under heavy boost it sometimes has a misfire (hard to explain, but feesl like a short loss of power. bit like a stutter.
This only happesn sometimes and usually when im in boosting hard in 3rd or 4th (around the 400rpm).
I guess it feels like a minor electrical problem (not that im qualified to know!)
I've done some reading but basically so many things to check I dont know where to start.
Anyone have any ideas before i take it back to shop?
thanks
How old are youe coil packs?
What type of plugs are you using @ what size gap?
If the shop tuned it, I would expwct them to put new plugs in.
I would be pointing to old coil lacks that are breaking down under boost
I have a feeling you are probably right with coil packs?? I've never changed them since ive had car (5 Years)
Car made really good power considering the little mods (i couldnt believe the dyno sheet).
I had the plugs done a few years ago and used irridiums.
Say it is the coil packs (cos i dont know what else it could be!) is there any harm leaving it like this? Specially considering i rarely need to drive it that hard.
Thanks!!!!!
Perhaps look at new coil packs? New plugs gapped to 0.8? Hows your coil pack loom looking?
In the DIY, Tutorials forum there is a stickied thread about misfire on an rb. Have a read, might find your answer in there?
thanks for the replies guys.
In terms of the tuning im not exactly sure. Basically my stock turbo let go so i got a GCG hi flow. The tuning was on the dyno to get it perform as best as it could without comprimising reliability.
It is my daily driver so I need to make sure it is reliable.
like i said I was surprised surprised to see the dyno sheet (225kw) and how amazing it runs.
most times the car is spot on and feels great. only occassionly when i drive it very hard (which i dont normally do, did it to see how the turbo felt) does it do it.
I have a feeling it is the plugs or coil packs.... not that id know.
If it is - considering that hte problem hardly ever happens could i be causing any problems be driving it like that?
thanks for your the replies!!
yeah if its making that sort of power you will be hitting the standard ECU protection - TTPMax
what are you using to control boost, is it a controller or just the actuator spring?
if you are using a boost controller turn it to 2psi and see how it goes
if you arent using a boost controller then you are stuck with the minimum boost possible from the acutator spring, its probably 1 bar, which is prob too much for stock ecu
let us know answer to first question (controller or not)
have you got a fuel pump? this thing could be leaning out on boost if you haven't, mine leaned out on the stock turbo and 0.85kgcm2 and yours is highflow with more boost
thanks for the replies again.
the boost controller is just the manual boost T, the cheap $30 ones.
not sure i get how the boost is working, well specifically why the minimum would be 1 bar? my standard turbo was set to 10psi. now with the hiflow the shop set it electronically to 11 (ok well on the dyno sheet that is where it is making the power). that said, my gauge can be pushed to 14.
Fuel pump is stock also.... my plan was to only upgrade things when and if the break. Hence the turbo.
Thanks again!
hey mate as old mate said a couple of replys ago i would start with new plugs bkr6es there $8.20 each at burson, I would say its missing due to the car making more power and ur shitty old plugs cant handle the load in 3rd and 4th and if you can i would replace the fuel pump asap cause the standard pump would only be good for a little over 200rwkw and im guessing its the original pump so it around 15yo and u dont want to lean ur motor out everytime u hit boost
ok. I've popped the top of and got to the coil packs / plugs.
Changing plugs will be my next step - though wondering if there is any way to determine whether one of the coil packs is stuffed?
I thought runnign the car in the dark might have shown sparks if there was a crack. i may have been wrong but I definetly didn't see anything.
any help appreciated!
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
