Varrosten 19" 2.2.2 On A R34 Gt?
R34L_R34
 Share
Hey guys,
just need some help deciding sizes on which sized rims to get on my R34 GT?
The car currently has an impul kit with S15 stockies.. doesnt look too good without the right rims.
I know 18"s would be enough.. but I'd like to go with 19"s!
What I'm thinking of getting are: 19" + 9.5 with a +22 offset with 245/35/19 tyres on the front, and 19" +10.5 with a +22 offset with 265/35/19 tyres on the back.
I just need to know if i'll definitely need to roll / flare my guards on the back? or do I need to do the same on the front as well?
Cheers,
Edited by R34L_R34
Not sure how different R33 and R34 brake setups are BUT I test fitted a set of Varrstoen 2.2.2 19x9.5 +22 on the front and for some reason, it fouled on the brake caliper (where the "Nissan" writing was).
I was always under the assumption that the closer to 0 the offset is, the further away it'd be but I think the spoke design is what caused the rubbing of the caliper. Just something to think about :thumbsup:
Edited by turbodragon
  • 2 months later...
I have the 9.5 +22 all round on mine and they fit fine but not to sure bout the 10.5.. I am running coilovers and its jacked up pretty much as high as they go atm.. Still in the build stage.. This is what they look like..
photo (2)222
Firstly let me say, they look great, and will look even better once you lower it some, BUT, if those are Varrestoens, do yourself a favour and remove the Volk and Rays stickers....
Otherwise you might as well go and stick a gtr badge on the car....
Hahaha I knew it was only a matter of time before someone had a go at me for that.. It was my brothers idea, and he had a set of genuine stickers so we put them on.. I like the look of the stickers, but im definately first to jump and let ppl know they arnt real haha
Well what about some custom ones? As opposed to, don't take this the wrong way but 'posing as' Volk rims?
(No this is not a shameless plug for myself but i can assist with this....)
People can think what they want.. I think i like it how it is, and yeah one day il prob get over it and take them off but until then oh well.. Whoever owned it before me put a nur spec badge on it.. I don't want to take it off cause it will prob leave a mark.. And I may be getting a whole new rear bar anyways so it will come off then.. Gtt. .
 Share
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
    • I have two questions here, The first is regarding the harness attached to the power window and central locking control on the drivers door. I can't understand why the previous owner would join these wires together on the harness and why they did such a shit job. There was a wire with 10v hanging in the open un insulated. The OEM remote control works just fine The second is regarding the blue, green wire attached to what I believe is the lock actuator? These were running to the old immobiliser connected to the 'UNLOCK - COM' and 'LOCK - COM' wires. I imagine COM means communication and they just send a signal to the immobiliser whether the car is locked/unlocked?  IMG_9032.HEIC IMG_9037.HEIC IMG_9038.HEIC IMG_9041.HEIC
    • A name I haven't seen in a while, welcome back. Nothing much has changed, we are all still deluded Nissan owners.
