I bought a 1993 r32 4 door with a factory rb25de but it was blown so I replaced it with rb20det which was a straight swap. I used the rb20det engine loom which plugged straight into the r32 all was good so far, then it came to starting it. it cranks over like a champ and compression is good its getting spark and it gets fuel but its to much then it floods the first 3 cylinders and wont fire.
But if u leave it to dry out and unplug the fuel pump and use start ya bastard it fires straight away then while its running plug the fuel pump back in fuels up abit but then comes good and runs fine until i turn it off and try to start it again with the pump plugged in so it floods it again.
Now I changed the injectors that didn't help, i changed the reg that didn't help and the ECU is showing codes for coolant sensor which has broken wire on it and the other is knock system but i plugged the knock sensors in and that cleared that code but it still wont start. I'm out of ideas and getting very pissed off. Any help would be awsome
https://www.sau.com.au/forums/topic/391478-rb20det-wont-start-help/
So did you fix the coolant temp sensor?
You sure because it is one of the main influences on fuel adjustment - including cranking injector on time.
Are you sure its only flooding the front three cylinder?
oh ok will do that 2morrow then. yea its the first 3 pulled all the plugs out and rear 3 were fine and front 3 were swimmin in fuel
You say you changed injectors. Same rail or different rail with seated injectors? I'm going to say leaky injector seals whether it be rail to plenum or injectors to rail. They aren't really a reusable item.
yea i changed the first 3 injectors and used the same rail that was on the engine. its strange that 3 different injectors did the same thing and theres no sign of leaking from rail to injector. why cant they be reused?
Have you considered that the ECU is delivering enough fuel to run a 2.5l engine, and you only have a 2l engine?
It may also be affected by a possibly different set of pinouts to drive the injectors, ie only injectors on 1/2/3 are the same between RB20DET/RB25DE, and 4/5/6 are totally different pins, so 4/5/6 never get injection.
Surely he couldn't be silly enough to run the r32 ecu...
most sealing components used to seal fuel components will pretty much shit it once they are exposed to air. those rubbers are old and brittle.
Blind_elk if that was case (no fuel in 4 5 6) surely the car wouldn't be ruining fine after he started it...
Get new O rings dude. Or try swap injectors 1 2 3 with 4 5 6 and see if that wets cylinder 4 5 6. Make sure you swap ALL seals over too, so which ever injector seats you have in 1 2 3 put them in 4 5 6.
Edited by SargeRX8
Repace all the o rings mine where leaking in my 20 but the car would still run no problems. Did you clean the injectors before running the car
nah trying to keep cost down. on another note i took the rail off the plenum and left the injectors in the rail then I pressurised the system and no fuel leaked out of the injectors
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
    • I did a motokhana years ago with ??Sydney Sporting Car Club???, it was on a grassy paddock and was heaps of fun, I think it was north west Sydney IIRC The old R33 boat was covered in grass and dirt, but nothing that a good wash and detail didn't fix And thinking back, when SAU did the airstrip run in Goulburn years ago, where the old 33 won highest RWD MPH, the quickest RWD ET on the airstrip, and best paint IIRC (before the runs down the airstrip) the damage to the rear quarters from stones flicking up required them the get a respray  I would definitely do a grass motokhana again in the MX5 Who knows someone that owns a farm with a big empty paddock  Liability these days is a big issue though
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
