some time in the not to dstant future i hope to perform the following mods to my currently stock r33 (besides zorst and springs) and get the thing doin 11s over the 1/4
garrett gt3040 600hp turbo
trbosmart 45mm waste gate
trust type r bov
100mm thick front mount
1.6mm head gasket
680cc injectors
044 bosch fuel pump
microtech
greedy profec b spec 2 boost controler
apexi air filter
brass button or twin plate clutch
maybe 250 degree cams
nittos
move throttel body to front of plenum
and later on forgies and maybe some slicks
this set up is much the same as the hpi r34 gtt , it runs 11.9 on nittos and has 296rwkw , hopefully my set up will give same or better results. any doos or dnts about my set up, wat do uz think bout it?
https://www.sau.com.au/forums/topic/39149-r33-gtst-quest-for-11s/
Power fc and tune $2000 tops
FMIC $1300 for a 1/2 decent one
Turbo back exhaust $1300
Nitrous kit & instalation $2000 tops with tune plus ongoing cost of filling bottle
$100-$500 for decent rims for 16" tyres if thats what you use
$700-$900 for 16" drag radials
more then likely you should already have exhaust or fmic in which I'd spend the money left from that on camber kit, pineapples etc to help with launch
So easily no more then $8000
Perspectives have changed in more than a few peoples minds lately, hey?!?!? Not just yours Brett, you know the number of pm's and emails i've had? It's just amazing. Like you said, makes ya look at any 33 gtst with a front mount and exhaust a little differently...
Adrian
Nah Adrian I still think its false power because you can't use it all the time and don't think adding it to a car would add value to the car the way a after market turbo kit would, but if its just a quick fix and fast time you want its the way to go for sure, but as you know I'm a mod person so we'll all have different opinions which is fair enough
Brett
Cost using nitrous for 11's.
Nitrous Kit + fit = less than $2k
Big ass Fuel pump (needs to be big enough to feed the motor and the nitrous kit) = $500
Fuel pressure reg = $200
Pineapples (diff cradle kit) = $100
Drag radials = $700
New ceramic puck clutch plate (if your present one is factory organic) = $500
thats about $4k to do the 11's.
You don't need a fmic or even an aftermarket ecu. A second hand S-afc for $350 will be nice for off the gas but, otherwise not necessary.
WTF is false power?
So? I'm talking about peoples perspectives changing in regards to nitrous use at the drags (i.e quest for 11's). Who gives a sh1t whether it adds value to the car?!?!? That's all I meant.
That's what he wanted.
All of a sudden Nitrous isn't a modification?!?! WTF?!?!?
P.S. you're purple glowing name is ghey!
Adrian
buster,
sadly didn't get to take the car to the strip before kangaroo's made me sell a few things to adrian.
I had plenty of fun none the less. From experience I'd say even with the 205's on the back I would have managed a very entertaining mid/low 12. I was running around double the shot of gas adrian was at one stage.
WTF is false power?
Maybe the wrong choice of word on my part, I meant I like my power all the time not JUST when I'm at the drags
where does he state he wants a quick fix?
Once again I meant I like modifications that I gain from every time I drive the car, so I can enjoy the power all the time
I was only giving my perspective as you said
"Perspectives have changed in more than a few peoples minds lately, hey?!?!?"
and I was stating no it hadn't really in my mind as I like an 11 sec car all the time not only some of the time
No use in getting upset though, we can all have different opinions :P
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
