hey guys i know this sounds like a retarded idea but i wanna put the sub setup the the R35 has into a 32 gtr, has anyone done this or know who the best person is to speak to, upholsterer, Alberts car sterio or a sterio mob?
Cheers
https://www.sau.com.au/forums/topic/391493-r35-bose-subs-in-r32-gtr/
yep its retarded, BLOSE car audio suck frothy sweaty balls . you can build a box that sounds better and takes twice the power and same space , why would you use that rubbish ? recycle it and be kind to the planet
any sane installer would say no way. its a step backwards compared to the cost to use it. pro car audio walks all over BLOSE stuff, even cheap speakers are better then BLOSE if used in a good custom box
did I mention BLOSE is junk , most are just paper cone drivers that die in the heat and wet weather (even the famous 301- 901 home speakers are paper cones in good tuned boxes) , low ohm load speakers with low power built in amps , used in a 7th order bandpass box, double reflex box to improve the sound
ok one more time, it sucks and isnt worth it. break it open and use the magnet for your fridge photos cause thats all its good for or to replace a dead one in another R35 ?
I wouldnt install it in my crapper
yeah i see what u guys are saying i only ment it as a concept as you say cause i couldnt figure any other way to explain what i wanted.
yeah i ment like have the subs in a custom box with maybe some rockford T1's in the rear seat.
You could do it
Police and thieves will love you
To remove the rear seat you have to re registet your car as a two seater and weldup sealup the holes etc or defect magnet
A small comsole with sub would be ok like r35 but lots of better options exist
troy, R32 had a drop down centre armrest. that makes the concept a bit easier. only thing being is that I am not sure if that was a sedan only thing or a trim level on the 32. mine does not have it. also the steel barrier behind the seat would need modding and strengthening.
You could do it
what sort of options do i have?
I cant really put them in the boot with the Battery and the fuel system?
plenty of room in the side panels in the boot ? the side panels in the rear seat area, or buld a console to merge with the front, or ditch the not so light weight spare ?a little fiberglass and a shallow mount sub on one side, amp the other side done
chris some 32's have the arm rest , some dont, I've seen a few without it, not sure what option level it is ? but anyway I understood the concept portion inbetween the seats. just BLOSE speakers are average at best compared to other options
yeah i totally agree bose are terrible, hmm u have given me alot to think over
cheers
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
