My factory Stagea body stripes are fading abit. Going on the hunt for a QUALITY business for reproductions, anyone interested? They look awesome, they break up the look of the side of the C34. They are no longer available from Nissan. They came in two colours/formats only. Light & dark (light for dark coloured vehicles, dark for light coloured vehicles). The dark ones are metallic silver (as fiited to my C34, see pic, but unsure as the light ones, as I have never seen another Stagea with them. If anyone out there has info, post it up!!!!!!
https://www.sau.com.au/forums/topic/391495-c34-body-stripes/
a local dealer option in japan, the problem is when you put any stickers on they tend to fade in areas of the paintwork when taken off.
i like them but there was a thread regarding this, when terry was going to put the full nismo sticker set on his N1 R34 GTR.
I know the paint will be brighterish under the decals/stickers, I worked in the dealership industry for over 10yrs, & have seen this problem, but the new ones will go directly over where the old ones were, with tape applied along the outside lines, & with full measurements taken before the old ones are removed, which I will post up when the time comes.
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
