Hi all,
I'm currently buliding a R32 GTR for track work no rego etc. it is not running and in stripped down condition for seam welding and cage etc.
I need a little guidance on what coilovers i should use.
what i have are 2 sets in my parts collection to chose from to get the car strarted.
first are a set of TEIN super streets these are pretty much brand new.
and the other are a set of Racing gear JTC N1 and are little older but look in good condition.
I need to pick one set and sell the others i may upgrade later but first need to use what I have.
My car will pretty much be used for super sprints and hill climbs.
Grant, Count Grantleyish on here had them in his 33R. The rears are still in the car and I have the fronts cus apparently they felt too soft, that all comes down to personal opinion.
They look like great quality bits of gear and should be pretty decent for trackwork.
Do yours have Pillow ball uper mounts? If not grabbing a set of cusco's etc should make them feel a lot better.
Guys tryn to find out if im wasting my time using these
There are a huge number of factors affecting your suspension set up. It is never a case of throwing a set of springs/shocks at the car & thinking it job done.
If you are even half serious about it you will be spending a bundle of time getting it right & doubtless a bundle of money aswell.
Pick whicever one the spring rates suit you. You will end up changing stuff anyway.
Thebest option really is to hang onto both sets and try them out, work out what suits your needs better and flog off the other set. Maybe even try driving some mates cars etc with different setups and build your car from your own experience with products rather than people on the internet's opinions.
As Michael said, I had them on my previous 33R.
Very stiff for street, they really do make it handle amazing. Unfortunately, I killed front pair by driving it into a pothole, which is real shame cos they're really nice coilovers to use if you like stiff ride which I do, they could benefit with pillowball mounts as Michael said for direct ride feeling and shave 2 inches off the ride height if necessary.
Out of curiosity, what sort of tops do you have on yours?
Pretty sure mine are the ball type on the top have a swivel section in the top the car also has adjustabe everything. Camber castor toe swaybar links all front and back. Red springs in mine they look impressive. I'm amiming for times around 1:05-7 at wakie gtr will have 330wks racing brakes semi slicks.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
