I may be dropping a fresh rb26 into an r32 gtr shell, engines out of the car At the moment, new engine that will go in will be ready to drop In
How hard is it to put in and connect things like front drive shafts, gearbox, mounts etc etc?
Thinking of doing it here at home but not sure I can manage this task
Anyone know where and how much someone would charge to drop it in?
Thanks
https://www.sau.com.au/forums/topic/391548-r32-gtr-engine-install/
Gear box can be a bit of a mission for one person being very rear heavy, gearbox jack would help alot if ur by yourself
The nuts that bolt the engine mounts the the engine frame can be quite tediouse as there isn't much finger room to thread them in
Front shafts aren't too hard, most difficult part would be getting the splined part of the shaft through the hub as you'll need to pull the hub out to make room to slide it in... then there's 6 bolts on the passenger side which are pretty easy to do if the vehicle is jacked up
Ɨ
Ɨ
